slow/hard start low oil pressure at idel - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-03-2011, 06:26 PM Thread Starter
i have 04 350 that is hard to start cold or hot. when the trucks warms just alittle the oil pressure will drop to nothing. it has a lack of power but really noticeable after 2200 rpm. it has oil on top of the v so i removed the turbo and thought it could've been the oil return from turbo to the HPOP leaking so i replaced the o-rings and still no luck. truck had the same symptoms as b4. any help would be great i use this truck for work and its my peak time right now
fixinitmyself is offline
post #2 of 4 Old 02-03-2011, 06:47 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Possible oil pressure switch leaking. It's on the back side of the oil filter housing. I think it has a single wire connector.
dhanna6powerstroke is offline
post #3 of 4 Old 02-04-2011, 03:36 AM Thread Starter
how would a leaking oil pressure switch cause my problems? and how do i tell its leaking? visually?
post #4 of 4 Old 02-04-2011, 04:59 AM
Mod Newbie
Quoted: 20 Post(s)
I was referring to the leak and gauge issue.
