6.0 shut off, Now hard starting, running rough - Ford Powerstroke Diesel Forum
Old 02-01-2011, 12:56 PM
Hi, I have been a member of the forum for awhile, I've done alot of reading (lots of good info on here) but this is my first post.
My buddy is having some problems with his 2003 6.0 He recently bought the truck at an auction with 2 bad injectors. I replaced the injectors for him and it ran great for a few houndred miles. The other day the truck just shut off on him while driving down the road.
Now the truck is very hard to start and smoking alot of dark grey / black smoke. When the truck finally starts it runs very rough, wont hardly rev past idle, and wont stay running for very long, and still smoking alot after engine is running.
I recently got the Auto Enginuity software with the Ford enhancement and am going to hook it up to the truck tomorrow. Does anyone have any ideas to what the problem could be? Anything specific to check with the AE?
The truck does not have a chip / programmer in it, it does have the EGR delete, O-Ringed heads, Arp studs. The FICM was replaced recently also from what the guy at the auction said.
Any help / ideas on this would be great.
Thanks
Old 02-02-2011, 05:27 PM
mine did that found out to be two injectors leaking air into the system and was causing the engine to die. Try checking for air into the system after you scan it with your ae.
Old 02-02-2011, 05:30 PM
that sound like you may have a egr sticking trying pulling it out and cking to see if there is and crap stuck in it i have seen that happen a few times
Old 02-02-2011, 05:42 PM
I am just curious. How did you figure out it had 2 bad injectors? My buddies truck is in the shop right now because it was running rough and white smoking and the guy is saying that 3 injectors are bad. Wouldnt there be some type of codes?
Old 02-02-2011, 05:48 PM
scaners have a cut out test or contribution test that will tell you
Old 02-05-2011, 06:15 PM
mine didnt throw any codes but i disabled the ficm and my fuel pump. had a friend comeover and crank it over while i watched for air in the fuel bowl. Tore the truck apart and found two copper washers were leaking on the injectors.
Old 02-06-2011, 06:07 AM
What did you torque the injectors to when replacing them??
Old 02-06-2011, 07:53 PM
24 ftlbs for the t-40 bolts
