FICM Voltage Test Results Question? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-16-2011, 11:13 AM Thread Starter
I am having a pretty serious cold start issue with my '05 6.0L at temperatures below about 40F. I have measured the fuel pressure which appears fine. I've checked the Glow Plugs and they appear to all be working. The truck has the lattest flash.
I tested my FICM voltage and see the following behavior (had truck on battery charger during test):
1) Key on FICM Voltage: 24V for 3 seconds (approx) and then it jumps up the 48.5V
2) Key on and crank immediately: 48.5V
- NOTE: I see the 24V reading for that second until until I start cranking the engine and then it immediately jumps up to 48.5V
- NOTE: I tested both with and w/o my Glow Plug Control Module powered but did not see any difference in behavior.
Can anybody tell me what is happening during those first three seconds as related to FICM voltage?
Thanks
usfunks is offline
post #2 of 13 Old 01-16-2011, 03:46 PM
Powerstroke Techie
forddieseldoctor's Avatar
Sounds like a failing ficm to me.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #3 of 13 Old 01-16-2011, 07:38 PM Thread Starter
Thanks,
Is this the type of symptoms that are correctable with the FICM "re-solder" mod? Or should I get our my credit card?
usfunks is offline
post #4 of 13 Old 01-17-2011, 03:51 AM
Are you convinced it is the ficm? Before I'd pull out the CC, I would eliminate other potential contributors. What are your "serious cold start issues"? Long cranking to start? Running rough when cold?
deucer is offline
post #5 of 13 Old 01-17-2011, 09:26 AM
Chango's Avatar
Spend some time reading thru threads here using the search function for "cold start" cause there are a few different problems that people have run into.
Check out the cold start thread in my sig, it helped with my problem
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
post #6 of 13 Old 01-17-2011, 08:03 PM Thread Starter
When the temps fall below about 35F I have very long crank times and it sounds/feels like when the engine finally fires it is only running on a couple cylinders and will most likely stall 2 or 3 times before it finally coughs and sputters long enough to start warming up. This is a new problem this winter as I have never experienced this problem in the previous 5 winters.
I have always kept the oil changed on 5K miles (or less) intervals and kept the fuel filters clean.
I recently tested all of the glow plugs and the controller which all tested fine. I also tested the fuel pressure. Fuel pressure was a bit low at 48psi so I upgraded to the "blue" spring from ford. This hasn't really fixed anything but I feel better keeping the fuel pressure up (runs 58psi now).
With all of the threads out there on FICM voltages, I tested mine and noted a behavior that I haven't seen documented in any of the threads which is described in my original post.
Thanks for the questions and advice.
usfunks is offline
post #7 of 13 Old 01-17-2011, 08:06 PM
sounds like stiction to me. check the cold start link in my sig
obsidian is offline
post #8 of 13 Old 01-17-2011, 08:38 PM Thread Starter
Stiction could well be a significant part of my issue. I changed my oil and filter last weekend and added Rev-X. Figured it can't hurt. Anyways I am trying to undertand why I am measuring 24V from my FICM durring the key-on buzz test as I described above. I don't think this is normal from all of the threads I have read.
Maybe the Rev-X will fix my stiction problem but I would also think that the inductive heating flash should also help but it hasn't done Jack. That is why I decided to probe the FICM voltage.
Thanks
usfunks is offline
post #9 of 13 Old 01-19-2011, 05:56 AM
my 05 had the same voltage reading on the ficm that yours has with the 24v for a few seconds then would go to 48v and about two weeks later my ficm went completely out and would not crank.
powerking is offline
post #10 of 13 Old 01-21-2011, 05:47 PM Thread Starter
Going to pull the FICM and peform the "FICM UPGRADE" from the 6.0 Tech Files folder this weekend.
I will update with post upgrade measurements when I am done.
usfunks is offline
