Engin Stalls after about 15 miles
I have a 2004 F-250 6.0L with 80,000 miles. When I first start up I can drive maybe 15 miles befor the problem starts. It dosent spit or sputter it just loses power to the point I need to get off the road it also emitts a real light blue colored smoke. It dosent compleatly die and I can put it in neutral work the gas pedal a little till it clears up. It has done this maybe once or twice a year since I bought the truck in 04 with 10,000 miles on it, But I would change the fuel filters and all would be good for another 6 or 8 months. But this last time the filters didnt make any difference. It starts right up and runs like a sewing machine while in neutral, reves up good sounds great no smoke no problems, setting still. Always in the past it seemed that making a right hand turn would kinda set it off as was the case this time also. I thought maybe the fuel tank had been contaminated and removed it yesterday. It was really very clean. I`m going to reinstall it today and try fresh fuel from a different source and see if that helps. Is there any other suggestions. Onne other thing I should mention, When I bought the truck the water in fuel light was on. Knowing nothing about the truck I took it to Ford in Las Vegas and they took care of it. (at a price) Now I get what looks like rust out of the water/fuel drain plug. Please help
Have you pulled the cap off the fuel filter bowl on top and turn the key on to make sure it is filling properly? You say the fuel looks like rust, yet the tank looks clean inside? I'd break the fuel lines loose front and back and flush with a fuel and air compressor to ensure the lines are clean. Process of elimination: Good fuel flow from tank to top filter bowl and it is filling properly. Clean fuel should be entering top filter bowl. After you have confirmed you are getting proper and clean fuel to top and it is still not running right, I would then question what your fuel pressure is at that point. It could be a weak fuel pump or possibly Injector issues, but I doubt it's Injectors just yet. Does it throw any codes?
hmmmm. Im not sure what to do about rust in the HFCM, pull the filters out and see if their clogged up with crap? The whole right hand turn thing is odd, hopefully someone intelligent will have some answers
It was the right hand turn thing that pointed me to the fuel tank. It has new filters
Good point 'Chango'. That went right by me. The fact that it stalls while turning right could be because of insufficient fuel pressure and when you turn, the load/fuel obviously is pushed back away. This could be telling you that it is a fuel pressure issue, i.e. pump.
I think you can run a pressure check to find out if it is functioning properly first. As for cleaning it, that I don't know. I assume it works on a diaphragm concept and it maybe leaking there. If you can have it tested or perform a pressure test first, that would be the smart approach.
Thats what I`ll do. Thanks for your help, Joe
