No start 6.0 go figure
would a bad turbo cause a no start situation? ran into the store for 5 min when i got back in the truck it wouldnt crank. took about 10 min to get it to start. have been noticing a weird noise under the hood only thing i can think of is turbo just dont know if that would cause it not to start?
I dont believe a turbo can cause a no start condition. If your truck was already warm and it wouldnt start I think the most common occurence is either the IPR or ICP sensor, check out the troubleshooting guide in my sig. Good luck
im going to check the batteries when i get off work today they are motocraft so if they are the originals from 05 i bet they are getting weak and that was the problem just pissed me off seems like with this truck its always something
and the sound im hearing might have been there before and i never noticed it and im just a little paranoid after my oil cooler went idk
Yeah. Batteries is a good place to start, hopefully it hasnt taken out any other things I know I have read where low batteries have messed with the FICM and other electrical stuff
i hope not i need to find some time to go to the dealer and see if its got any codes. hopefully its nothing that will leave me without a truck. I was also thinking maybe oil pump since i had my oil cooler go out a couple of weeks ago and i didnt know if it might cause the pump to go out or anything.
ok went to the local autozone and got my alternator and batteries tested and all is good there, so now im guessing either my spring for the fuel pressure is getting weak or oil pressure since it runs perfect once it starts and its just an every couple of days thing. the thing i dont understand is it only does it when the motor is warm never had it do it to me on a cold start.
Simple to check if you are getting fuel. Pull the cap off fuel filter bowl on top. Turn key on and look at fuel filter bowl. It should fill up very quickly and spill over. If it doesn't, you have a fuel feed issue.
hpo leaks will cause hard/no-start issues when hot.
sounds like the dummy plugs are leaking. i would air test it and see if you hear any noise from under valve covers
