Fuel Leak help - Ford Powerstroke Diesel Forum
Old 12-27-2010, 06:19 AM
Fuel Leak help
I have fuel leaking from the bottom of the plate in the picture. I can fix it myself, but I have an ESP that should cover it if it's more involved...
Is there an o-ring that seals it or what? I couldn't find a good drawing, or part number. What's behind there?
Old 01-01-2011, 07:34 AM
No help? I thought someone might have an idea of what I'd be up against before I start tearing into it...
I did a pretty thorough search and found nothing on fuel leaking from that area..
Old 01-01-2011, 03:03 PM
Fuel pressure regulator. Has an O-ring that flattens out over time and leaks. I would have entire regulator replaced since updated regulator bumps fuel pressure up supplying more fuel to injectors.
Old 01-01-2011, 04:32 PM
Powerstroke Techie
......and 3C3Z-9T517-AG is the part number from Ford for everything needed in the kit.
Old 01-01-2011, 06:04 PM
Thanks a million guys!
I pulled it tonight and found the o-ring flattened. I assume it's all in the kit?
Old 01-01-2011, 06:09 PM
Powerstroke Techie
The kit in the part number I posted above, consists of everything in the photo, along with the updated spring and four new TX-27 bolts.
Old 01-01-2011, 06:17 PM
Good deal. I also like hot women with big boobies BTW!
Old 01-11-2011, 05:13 AM
Got the leak fixed, and the updated spring really helped the truck feel more snappy. It feels much better!
