Ok I have been on here all day looking for someone that has ran into my same problem, Im pretty sure im the only one that has ran into this problem. Ok here goes: I have a 2003 F350 with the lovely 6.0 I went on Christmas eve to get the rig washed up and ready for some festivities, went the the car wash and vacuumed it out, get im my truck start it up... all good, start pulling out of the parking lot and hmmmm no turbo spool, ok.... so I pull over and I can hear the turbo boosting up and coming down (like its supposed to) get it home (found that at wide open throttle the turbo would finally spool) get it home get ready for the night, hop in and I have a no crank issue, mess with my range selector but still nothing, figured it was a blown fuse. Started looking at it today, checked all fuses found nothing, got on the trusty old forum, found similar issues with no cranks, but nothing for not cranking, no fuel pump sound, and the wts stays on for an extended period of time, mind you this happened immediately after getting a car wash~!??!!?!?!??!?!??!? I try to plug in my snap-on "Brick" and it wont pull an info says "error" used a different code reader same thing... I checked my oil, found it was a little low (2 or 3 quarts) changed fuel filters earlier in the week along with the oil, checked all fuses, no click coming from relays, disconnected batteries for a hard reset still nothing. Checked fuel inertia cut off switch it wasnt popped, but it would still crank, was hoping that I Just needed to add oil- wrong! any help would be awesome, this is a new truck to me, it only has 89k on it, it has an AFE intake, edge platinum (previous owner had it on there, im changing if for an SCT as soon as I can). and 4 inch exhaust. battery voltage is good 12.25v. havent done a load test on em yet.
