engine miss - Ford Powerstroke Diesel Forum
Old 12-25-2010, 03:55 PM
engine miss
Sometimes at a stop light when the truck is in gear and I'm stopped with my foot on the brake my engine seems to have a miss in it. It's not the air compressor engaging or disengaging, and no codes. What else could it be?
Old 12-26-2010, 07:07 AM
I have had the same issues with and intermitent miss fire. Both times it was an injector or two that was bad.
Old 12-26-2010, 07:53 AM
Did your truck still seem to start, and drive smoothly?
Old 12-26-2010, 08:01 AM
Mine does something similar, except i wouldnt call it a miss. It makes the truck rock slightly, but when i put it in park it stops. Sound similar?
Old 12-26-2010, 08:08 AM
That's what it's doin.
Old 12-26-2010, 09:24 AM
Wish i had an answer for you but i figured it may just be the nature of the beast.
Old 12-26-2010, 09:33 AM
Almostdunfukinwidit
Its injector stiction. Lemme guess it only happens cold
Old 12-26-2010, 09:56 AM
Yes sir. I think it was about 9 degrees when I noticed it last.
Old 12-26-2010, 02:29 PM
Thanks Dave, I just read an article on Injector Stiction. Seems maybe a simple oil change is in order. I have only 1,200 miles on this set of filters. I wonder if I can get by swapping out just the oil. This time of year where I am is normally between 10 - 30 degrees. I have 15/40 Rotella in it now and looks like I should be using 10/30w.
Old 12-26-2010, 02:32 PM
Almostdunfukinwidit
Add two bottles of Rev X with your oil change
About | REV-X Products, Inc.
If you have a stiction issue this will cure it
