Head Gasket replace what does rotate crankshaft until damper loacting notch for?
I replaced my head gaskets torqued the heads and noticed I missed the steps that says " Rotate crankshaft until damper locating notch is in six o clock position"
I never moved the engine at all what is this for? |
proper timing with the cam would be my guess
the hydrolic lifters can spring a little when they are not under pressure from the push rods. the tollerance is very close and it could bend a push rod depending on the location of the pistons.
I ran into the same situation when I did my head gaskets. I scoured everywhere and finally found the answer...
If you look at the face of the dampener, you will see a line-up or locating dowel. Put it at the 6 o'clock position... That is what it means... If it is not at the 6 o'clock, you run the risk of bending some rods. When you look at the front of the dampener, you will know what I mean. I don't have a pic of it, but just picture the dampener removed, there will be a dowel sticking out that you have to line up the hole in the dampener to get it to fit right. Now, that doesn't mean go remove it to see... You will see the head of the dowel pin with the dampener on... I hope this makes sense... |
So I did not rotate the crank to where it should be and I have everything torqued including the rockers. Should i just loosen the rockers and rotate the engine? How does roatating the engine prevent the valve from going down to far because the hydraulic lifters will not be pumped up immdiatly anways?
Any suggestions to what I should do since I tigtened everything down without rotate to the proper position?
I have no clue if you should loosen them up, get the crank into position then re-torque. i remember reading on here that some did the same thing you did and bent some pushrods... If it were me, I would re-do it just for piece of mind.
Bull****!!! You don't have to rotate crankshaft... Logic FOLKS! If you rotate the crankshaft to the 6 O'clock position what did you gain? Unless you removed the timing belt, NOTHING! All pistons are sequenced to the crank and all lifters are sequenced to the cam. The only item that ties them together is an item called a timing belt or chain. The 6.0L is predicated on a ZERO lash for Rocker Arm to Valve Spring tension or torque. It doesn't matter where the crankshaft is as long as you did not touch the timing belt.
1. After head and rocker box is located and studs (hopefully) are inserted but not torqued, Install pushrods and rocker arms, but do not torque these bolts. Only thread the rocker arm bolts in, to properly hold the pushrods under rockerarms. 2. Torque your head studs sequential, (follow the torque pattern). Complete the sequence of torquing up to 210 Ft. lbs. if using Ultra lube ARP. 3. Verify rockerarms and pushrods are still aligned (Lifter, pushrod, rockerarm). Then torque rockerarms. End of lecture... I'll challenge anyone on this issue. Last edited by deucer; 12-31-2010 at 06:49 PM. |
![]() Why are you being so bold on this. It is an extra step. Takes a few seconds to do.... In AllData step 7 of the cylinder head installation it specifically says: Caution: Rotate the crankshaft until the damper locating dowel notch is in the 6 o'clock position or engine damage can occur. Maybe that is not the only safe position. Maybe if it is at 9 o'clock is where you will get the damage. maybe 4 or whatever. It just gives you a reference where there will be no damage. Challenge all you want.. Most people on here are diesel enthusiasts and not Master Diesel Technicians.. We follow directions and err on the side of caution. Every one I do, I will make sure it is in the 6 o'clock position. Happy New Year!!!!! |
Oh and by the way.... Our engines don't have a timing belt or chain. It is gear driven...
