HELP - New truck, rough idle and fails to accelerate sometimes
About two weeks ago, I bought my first diesel
![]() It's an 06 F250 with 95,000 miles on it. While test driving it, I notices that when idling after the engine was warmed up, the RPM would start surging between 500 - 1000 RPM. Other than that the truck was in great shape. I took the truck to a mechanic who told me the problem was due to the fact that the fuel filter needed to be changed. Last week, I changed both the fuel filter and oil and the truck still would occasionally surge once the engine was warmed up. Today when driving, I was idling at a stop light and the engine started surging again. However, once the light turned green, I pressed on the accelerator, and the truck continued to idle. I pressed the accelerator to the floor and nothing happened. The truck just idled through the intersection... NOT FUN. I turned off onto a side street, and the truck stalled out, and it took a lot of cranking before it would start again. Being that I've never worked on diesels before, I have no clue where to start. searching for the problem. No codes come up. What should I check? FCIM? Accelerator pedal?
Check the throttle position censor. If it's going bad it can make the truck surge but I'm not to sure about the no start issue.
sounds ficm'ish maybe... do you still have warranty? 06, you might... take her in if you do if you dont you need to find a shop with the good scanners and dodads they will tell you if its ficm or now my ficm went and it acted similar on mine i had no engine light or anything on the dash, just didnt wanna accelerate past like thirty mph.... idled up and down like yours, check swamps ficm i hear good things if your near ohio i know a good shop that can rebuild or replace them
Well, just got back from Christmas vacation. I'm not sure if the truck has any warranty left. In the morning I will take it the the dealership and see.
If it is a sensor or something, I could check and replace it on my own and save the $100 deductible. Although I'm sure the FCIM is beyond my ability to diagnose. I have read that the ICP sensor can cause rough idling. Could this sensor also cause the truck to go into a "failsafe" mode and prevent the truck from accelerating? I doubt it, but I just wanted to check. |
FICM is easy to test with the right tools. It took me about 20 mins, check the threads in my sig for test procedure under "no start" thread
Thanks Chango, I will check that.
As I drove the truck last night, I finally got two CEL codes. P0299 (Turbo underbosst) and P2285 (ICP circuit low) I have found some information on testing the ICP sensor reading the pressure from a scan tool. Does anyone know what voltages it should be so that I can use my multimeter (I don't have the $2,000 scan tool) I just got back from the dealership, and the warranty expired on 12/22/2010. So I just missed it. So fixing the problem is on my own dollar now. |
sounds like an ICP issue. or trash in the screen of the ICP. But its hard to diagnose without having a scan tool. Maybe someone one here around you can help. Where you located.
Sounds like it is begining a hpop leak...
I hope it was just a bad connection, but I figure the problem will come back in a day or two. |
