HELP: up pipe leak wont go away! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-18-2010, 07:20 AM Thread Starter
kuntryquesttsi's Avatar
Truck is a 05 6.opps. Had an oil consumtion problem and had the turbo rebuilt.
The up pipe is leaking and hissing right where the pipe meets the turbo. it is NOT the flex pipe.
The leak only occurs when the two prong connector is plugged in. Assuming this is an electronic wastgate? Could this be bad??
1993 f-350 7.3IDI
1967 F-100 352
1958 Pan Head Ground up built NOT BOUGHT
kuntryquesttsi is offline
post #2 of 12 Old 12-18-2010, 04:28 PM
Perf Diesel Shop Owner's Avatar
Hey bud, that 2 terminal connector is the electro-hydraulic vane actuator. It is nothing like a wastegate in its design, but serves the purpose of controlling turbo speed similarly. The leak you are describing sounds as if when the vanes cycle closed, the backpressure created is escaping through a misalignment in the Y pipe-to-turbo joint or a beakage in the pipe or flange itself. Is it bad??...it is losing boost and the escaping hot gasses are feet from you as a driver just on the other side of the sheetmetal and poorly sealed firewall. Additionally, the accompanying soot is soiling the engine compartment and accelerating corosion to everything it covers. I will let you decide the severity, but I think you may want to get that corrected my man
Rich
2005 GMC Sierra 3500 CC/LB Dually LLY Dmax
2006 GMC Sierra 2500HD CC/SB SRW LBZ Dmax
2011 Chevy 3500 CC/SB SRW LML Dmax
2013 GMC SIerra Denali 3500 DRW LML Dmax
and 400+ Dodge/Ford/GM Diesel customers!
Perf Diesel Shop Owner is offline
post #3 of 12 Old 12-18-2010, 04:51 PM
ajpu1983's Avatar
I would loosen the bolts where the y-pipe meets the exhaust manifold and then loosen clamp up top this will allow you to move the y-pipe around in order to mate the turbo and y-pipe perfectly.
ajpu1983 is offline
post #4 of 12 Old 12-20-2010, 04:23 AM Thread Starter
I took the bolts out of the turbo, took the clamp off the down pipe tightened the up pipe clamp then re installed the rest of the stuff. Still leaks. The truck is not being driven. I'm going to have to check the up pipe for cracks.
1993 f-350 7.3IDI
1967 F-100 352
post #5 of 12 Old 12-21-2010, 04:27 PM
ssamsom's Avatar
I am having the exact same issue, been trying to correct it for the past 2 days. Bent the V-clamps and am ready to throw a grenade in the cab! Going to loosen loosen up-pipe to manifold connections on driver and passenger side as well as loosen the up-pipe to up-pipe connection. Would just take it to the dealer to get them re-aligned but there is a 2 week waiting list for a diesel tech.
2005 F-350 CCSB Lariat 4x4
  • King Ranch Interior Swap
  • Pro-Comp 35/12.5r18 Extreme Mud-Terrains
  • 2.5" Level
  • ARP Studs
  • Black Onyx HGs
  • Sinister EGR Delete
  • 03 Turbo
  • Hi-Jacker Fifth Wheel
1998 IH 4700
  • T444E
  • 6+ Eaton Fuller
  • 24' Box with Gate
1995 IH 4900 4x6 Tandem
  • DT466
  • 6+ Eaton Fuller
  • 26' Box with Gate
ssamsom is offline
post #6 of 12 Old 12-22-2010, 02:11 AM
Check for cracks FIRST, carefully look over flex joints and connection points on up pipe for soot (a flex mirror is indispensable). Check down pipe and up-pipe flanges for soot.
If you think a flange is misaligned, loosen everything, up-pipe to manifolds, (BTW, LS inner bolt a biotch) up-pipe to turbo clamp, Down pipe turbo clamp, and loosen turbo bolts.
Make sure clamps are FREE of flanges, shake clamps completely loose.
Align and tighten down pipe first, then up pipe to turbo, then up-pipe to manifolds, then turbo base bolts.
Having the turbo loose allows the turbo to "float" into position as you tighten your clamps. The up-pipe to manifolds have ball couplers which seal easier slightly misaligned, plus you can tweak them slightly utilizing the "flex" in the assembly.
My ultimate guess however is you have a crack in the up-pipe assembly somewhere, those clamp couplers on the turbo don't just loosen, they are pretty tenacious.
DELTAJOHN is offline
post #7 of 12 Old 12-22-2010, 02:32 AM
preston77's Avatar
I just tackled the same problem and it was the Y pipe from the manifolds to the turbo. It was onlf off by maybe 1/8". The stupid Y pipe has a round slot that isnt long at all and if you don't have it in the tiny little slot on the turbo it's just gonna keep leaking. It's such a small male to female slot that the clamp will go back on. I tried just tightening the clamp more and bent it out also. Took about 30 minutes to straighten it back out but once I got my neighbor over to hold a rope that I wrapped around it the Y pipe it sealed up and no more stupid hissing! I wasn't about to loosen all kinds of stuff up to allign it when I have grape ape for a neighbor........
preston77 is offline
post #8 of 12 Old 12-22-2010, 07:08 AM
ssamsom's Avatar
Turns out it was the block off plate on the EGR delete kit that seals up to the intake, didn't have the bolts tight enough so the leak was there. Tightened the bolts and sure enough one snapped off so now i need to drill it out and put in a new bolt somehow.
  • 2.5" Level
  • ARP Studs
  • Black Onyx HGs
  • 03 Turbo
1998 IH 4700
  • T444E
  • 6+ Eaton Fuller
  • 24' Box with Gate
  • DT466
  • 6+ Eaton Fuller
  • 26' Box with Gate
ssamsom is offline
post #9 of 12 Old 12-22-2010, 07:19 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
Pics of your neighbor... I had no idea you lived next door to a celebrity!
Damn, that sucks. Those bolts aren't very sturdy. Hope it goes well for you.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #10 of 12 Old 12-23-2010, 04:20 AM
preston77's Avatar
LMAO!!!! If you saw hm you would understand! Only dude I've ever seen get in a bar fight, pick someone up be their neck, mow down 3 pool tables, about 50 people and a very large DJ booth and still have the momentum throw the dude across the room. Sure am glad he's on my side!
