6.0 powerstroke injector - Ford Powerstroke Diesel Forum
Old 12-16-2010, 04:45 PM
I have a ??? i have a 2005 f350 6.0 powerstroke i was told that injector #1 and #3 are bad. whitch ones are those? if im facing the motor are they in driver or pas. side? it it evens on one side odds on the other? i need help!!
thanks
matt
Old 12-16-2010, 04:52 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
thanks
matt
1 and 3 are on passenger side,2 is on the driver side....fudge!!!!
Old 12-16-2010, 05:22 PM
so let me get this right pass side starting from front is injector #1-#3-#5-#7?
and driver side from front to rear in injector #2-#4-#6-#8?
is this right if so i was told other whise and i replaced the wrong injectors!!! thats prob. why it still runs like ****!!!! lol
Old 12-16-2010, 05:43 PM
yup,in that order fo sure....dangit,i hate to hear that,sorry....we all make mistakes..
Old 12-17-2010, 07:19 AM
Whats the problem with your truck and who told you they were bad? They dont always need replaced but if its a dealer they will say needs replaced since that takes care of the problem
Old 12-17-2010, 08:36 AM
so Chango, What else could be the problem, I have 3 that need changed, as per the dealer...
Old 12-17-2010, 01:52 PM
see codew for bad injectors everyday never changed one yet
unless dealer is paying. try this clear codes run two qts tcw3 two stroke oil and a double bottle of cetane boost and change oil and fuel filters and drive it like its a rental run it threw the grears hard full boost to redline, an a long highway ride or pull a heavy trailer on the higway. 6.0 is not made to idle or shift at low rpms. make sure everything is up to snuff trans fluid, coolant, tires
