whistling turbo
turbo makes loud whistling noise when driving
Most folks want that sound. What year is your truck and is this different from how it sounded in the past?
If it's an '03 that's normal. But like Evil Eye said: How is it different now?
I'm about to do the foil delete on mine to get more "sound" out of mine. |
the truck is an 07 and the noise has been getting worse
Can you give more specific detail about the noise, when, sounds like, certain parameters that it does it or not?
check all your connections to and from your turbo. with the truck running of course. try and do it after the truck has been sitting and cool that way everything isn't hot while you're searching around in there
The exhaust will heat up almost instantly.... not like an engine block taking some time.... just my $0.02
yeah, check your exhaust components first. shouldn't take more than a minute to check everything. if you have high idle mod done, it'll help push more air/exhaust through whatever is leaking. IF that's the problem
When the truck is under power it makes more noise.The noise started last spring. I noticed it just when I would put the truck under light power or accelerate. I really had to listen to hear the noise.I can also smell the exhaust in the cab. hope this helps Thanks
sounds like y pipe to me. known problem on a 6.0
