cut out after injectors replaced
after doing my injectors the other day my truck has been getting progressivlty better, except today i went out to start it and it started fine put it in drive and it died for a second and recovered and threw an engine light. pulled the codes they were for #8 cylinder and it said low circut, and low contribution on #8. do you guys think it could be that all the air is not out of the oil yet?
ok so i am getting a couple new codes now as well. ficm p0611, ipc sensore p2287 and a p0299 and p0284. any one have any suggestions? i am starting to think i have a short some where
check your connection at the injector, make sure it is straight on and connected properly it might be a bit on an angle and not contacting properly. May of also got a bad injector, I'd check your voltage for your FICM, should be approx 47-49v. Clear codes see what codes come back, an injector can make it throw a bunch of random codes too.
