Horrible Cold Starts....FICM?!? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-13-2010, 11:00 AM Thread Starter
06kingdeez's Avatar
Have an 06 king ranch and the past few weeks since the temps. have gotten in the teens at night it has had trouble starting, it will cycle the glow plugs and it will crank for a few times then just die. I have had to recharge both batteries twice in the past 3 days due to this...Also just had my egr deleted and didnt know if that would have something to do with it. Do i need to replace me FICM or could i use my bully dog programmer to clear it?....Ive also been using some dieselkleen fuel additive to try and improve the starts but its still rough.
06kingdeez is offline
post #2 of 13 Old 12-13-2010, 11:12 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
Sounds more like fuel gelling to me, but WTH do I know, it was 80* over the weekend here in Arizona.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 13 Old 12-13-2010, 11:25 AM
diablos30's Avatar
Quoted: 31 Post(s)
only one way to know if its the ficm, test it.
diablos30 is offline
post #4 of 13 Old 12-13-2010, 12:08 PM
Quoted: 9 Post(s)
Slow down on the FICM. With it being cold, I would bet that you have stiction problems before you had FICM problems. It could be the FICM, but somehow you need to test it before you just buy one and put it on. If it runs perfectly when it gets up to operating temp, it just might be the stiction. If it is, options are: Try something like Rev-x. It helped my 06 tremendously, switch to rotella 5t thinner oil.(I'm trying that next oil change), or replace injectors. Not sure if you can check FICM without analyzer. No real way to check for stiction beforehand that I know of.
divotf15 is offline
post #5 of 13 Old 12-13-2010, 12:12 PM
diablos30's Avatar
Quoted: 31 Post(s)
you can test the ficm with a multi-meter.
post #6 of 13 Old 12-13-2010, 01:02 PM
DesertSmoker's Avatar
This sounds a lot little like bad batteries with a typical 15/40 cold start. That is just a guess. .5 volts on our trucks makes a wold of difference when starting especially when it is cold.
2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #7 of 13 Old 12-14-2010, 12:28 PM Thread Starter
06kingdeez's Avatar
Tried Again Today and no luck.....this is killing me!
came out today to start her up and the temp. was about 20* and cranked it over 2 or 3 times with no luck. Plugged in my bully dog to try and clear any trouble codes and then tried again and as soon as i did that both batteries died. The shop that deleted my egr said my ficm probably needs to be replaced soon and that it is probably the reason my cold starts are so bad. Im gonna go get them recharged again and just take it to advanced auto to have them run a test. Would my alternator possibly be causing this. And would getting a custom tuned sct solve this problem or is ficm the only way to go. I know that .5 v difference can cause the truck to not start properly but is this my only route buying a new $700 ficm?????
post #8 of 13 Old 12-14-2010, 12:49 PM
diablos30's Avatar
Quoted: 31 Post(s)
the only way to know what is going on is to perform some TESTS. load TEST the batteries, load TEST the alternator, TEST the ficm, and that doesnt come up with anything you still need to TEST for other things such as icp, ipr, or hpo leaks.
if you havent caught on yet, you need to perform some tests. nobody is going to be able to use a magic 8 ball and tell you what is wrong with your truck unless you can give us some info to go off of. we can give you some ideas (see above), but it is up to you to perform those tests.
if you dont have the knowledge or tools, see if there is anyone on here that can lend a hand. if that isnt an option either, then take it in to a reputable shop (dealer if need be), because if it is the ficm it will kill your injectors.
post #9 of 13 Old 12-14-2010, 01:03 PM
Quoted: 9 Post(s)
How long are you letting it turn over each time when you say "2 or 3 times" When my HPOP went out I probably got 12 to 15 thirty second cranks before it even sounded like it was slowing down. I would check your voltages while you crank. If your batteries are giving descent amps but voltage below a minimum required, it might be the reason for the hard starts. At least charge up the batteries, put a charger on one battery, and jumper cables on the other battery from another RUNNING vehicle and see what she does for you. Either way it sounds like probably have a dead cell in one of the batteries if you are only getting 3 quick cranks on them. Does your radio go stupid every time you crank your truck?
Break Break: What's a 15/40 start?
divotf15 is offline
post #10 of 13 Old 12-14-2010, 01:10 PM
Quoted: 9 Post(s)
From the "really confused" posting in this section. "Was having what I thought were FICM problems with a no start. Turned out to be a blown alt, put a new one in with new batteries and fired right up and ran GREAT at idle for about 10 mins". He had some other problems, but you can see that low voltage on batteries can cause some strange symptoms.
divotf15 is offline
