quick ficm test questions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-11-2010, 11:19 AM Thread Starter
i have a 03 6.0. checked my ficm today.
at the pre-buzz position on- got no voltage
at the buzz got 48+with no drop
at engine start i got 48 + with no drop
is the engine on pre-buzz position correct with a no voltage reading, or should i be getting a reading there?
thanks for the help.
jim
boisdarc1 is offline
post #2 of 3 Old 12-11-2010, 12:24 PM
Check this:
FICM repair/upgrade
gary2070 is offline
post #3 of 3 Old 12-11-2010, 12:27 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 828 Post(s)
Feedback Score: 6 reviews
When the key is turned to the on position, your should see 48v as well.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
