please help looks like oil in my degas bottle
please help what would cause oil to come running out of degas bottle
2 Things come to mind, both bad news
Head gaskets Bad oil cooler which in turn means bad EGR cooler |
the pich up run fine but it just pors out
huh? If you have oil in your coolant don't drive it. that is a serious problem that can get expensive fast
It is your oil cooler. i am sure of it. delete your egr when the intake comes off. then do a headgasket test. then flush, flush and flush somemore but you can never really get that oil out.
Spend some time reading through the posts here on the .org to educate yourself about whats going on. Like everyone else said its most likely EGR cooler / oil cooler
Had the same thing happen 2 months ago, had to replace the oil cooler and egr cooler. If you caught it in time it could just be the egr and oil coler, oil coming out of the degas bootle doesn't anyways mean headgaskets. Don't drive it so you don't do anymore damage. Bulletproof diesel has really nice kits if you want to do it yourself, takes the weekend but it's not really that hard. Just be ready to do alot of flushing to get the oil out.
Everyone else pretty much covered this but this just happened to mine a week and a half ago while idling on location, and it was oil cooler not sure if they replaced the egr cooler too or not honestly for 3200 im thinkin not and am really glad i bought the ESP plan afterwards.
so i guess ill br tearin in to this soon what should i do to it while i have it apart i just as well do what i need to it while its down and apart.
Im not sure what all had to come apart but Head studs are a good idea, definitely EGR delete, and i think somewhere on here ive heard that you can actually delete that oil cooler as well which probably wouldnt be a bad idea since the way the service department talked when i was in there they are a common problem on the 6.0s. ive also heard that the oil in the rubber coolant hoses isnt good for them and its better to replace them, but i cant swear to that.
