External HG coolant leak? - Ford Powerstroke Diesel Forum
Old 12-07-2010, 12:08 PM
is this unheard of or does it happen? ive got a customer with a coolant leak that looks to be running right out of the back of the head. ive never seen or heard of head gaskets (on 6.0's) leaking externally other than maybe oil.
its a side job so i wont be able to put it under pressure until later, just looking for some input
Old 12-07-2010, 12:37 PM
i bet it is the big "o-ring" that goes between the front cover and intake, and it is running down the block. does it have and egr cooler still?
Old 12-07-2010, 02:28 PM
yeah it still has an egr cooler. do those leak externally?
Old 12-07-2010, 02:31 PM
They can. Or it could be the hose inbetween the oil and egr cooler.
Old 12-07-2010, 02:51 PM
i would pull the turbo off then presure test it.
Old 12-08-2010, 09:44 AM
found the leak last night, coming right out of the o-ring from the egr cooler to the intake. thanks guys
