So i was pulling out into a busy street, shifted from 2nd to 3rd then my motor just died. it was getting no fuel at all. I managed to get it pulled into a parking lot. tried to crank over and it wouldnt fire. My rpm's dont move at all but i still have power. Rightn now i have no mods but my exhaust. took it to a Ford dealer (i'm 80 miles from home. where i usually take it.) and they said probably wont be till much later today
anyone have any ideas? i'm kind of stuck here until i get it fixed.. thanks for all you support!
Could be anything. Did you get a check engine light? How about any codes?
Took it to the dealership they said i'm not getting any oil pressure at all, and they would like to look at it more tomorrow (figures) i have the Ford base car extended warranty. i hope its covered!
Sounds like an engine problem which should be covered under the 5 year, 100k mile engine warranty.
hope it's covered
hey man i don't sound good 4 gettin ur trk bak soon. if it's no base (low pressure oil) that they found, good chance needs oil pump, front cover & hydraulic roller lifters.
if it's high oil psi thats the prob then likely just a short coupler under turbo in high psi pump area. let us no what u learn pls. if it's low psi, make sure they look after the root of the failure or it will hapen again. |
What was the issue?
It ended being my injection pump and high pressure oil pump. Damn good thing I got the warranty!!
