oring on top of 6.0 injector - Ford Powerstroke Diesel Forum
Old 12-05-2010, 10:52 PM
Is the oring between the top of the injector and the oil log on a 03 6.0 serviceable. If so anyone have a part number my parts Guy keeps giving me the kit for the head to injector orings. I have a small leak and would like to try to fix it without spending 300 bucks on a new injector. Already shelled out 1400 for a hpop headgaskets studs and related parts and fluids this week.
Old 12-06-2010, 07:38 AM
Unfortunately, I'm fairly sure that o-ring is only replaced during an injector reman. Don't quote me on that though. Who did your HG job? All the more reason to be super careful when reinstalling the oil rail, if that was the cause.
Old 12-06-2010, 08:23 AM
I did the headgasket job the leak showed up during a pressure test during tear down. Man that is going to be an expensive piece of rubber.
Old 12-06-2010, 08:31 AM
Feedback Score: 3 reviews
It is not a servicable part, you have to get the whole injector. Yeah, I know it is dumb.
Old 12-06-2010, 09:22 AM
Just put some RTV around it before installing the rail.
J/K
Old 12-06-2010, 10:12 AM
I replaced 3 injectors and put new o-rings on the 4th and with the o-ring kit I recieved I got all of the o-rings including the one that seals the oil rail to the injector not sure if thats the one you are looking for
Old 12-06-2010, 03:43 PM
I bought a set of orings part number3c3z-9229-aa and it doesnt include that one is there maybe a different part number. My 6.0 is a first series may 03 motor wonder if maybe the injectors seal different from the new motors.
Yes the oring i am looking for is the one at the top of the injector that seals the oil rail to the injector.
Old 12-06-2010, 04:31 PM
it is not a serviceable o-ring....
Old 12-06-2010, 04:42 PM
You can get it here: http://www.alliantpower.com/seals.html It's an AP0002
If you go by the Ford/IH part number all you get is the copper washer and 2 o-rings
Old 12-06-2010, 04:59 PM
Powerstroke Techie
its definitely not serviceable as per ford
if someone could verify that it is serviceable through alliant then that may be of great help to some people, myself included. i might have to give them a call
edit- found it
http://www.alliantpower.com/pdf/APTB-0108-watermark.pdf
Tags
injector
