Frustrated update...FICM info that needs decifering.. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-05-2010, 09:44 PM Thread Starter
FuddleyPJones's Avatar
My AE program shows the following codes for the powertrain:
Enhanced Powertrain CAN
P0113 Intake Air Temperature Circuit High Input
P0230 Fuel Pump Primary Circuit
P0261 Cylinder 1 Injector Circuit Low
P0264 Cylinder 2 Injector Circuit Low
P0267 Cylinder 3 Injector Circuit Low
P0270 Cylinder 4 Injector Circuit Low
P0272 Cylinder 4 Injector Circuit Contribution / Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0276 Cylinder 6 Injector Circuit Low
P0279 Cylinder 7 Injector Circuit Low
P0282 Cylinder 8 Injector Circuit Low
P0284 Cylinder 8 Injector Circuit Contribution / Balance Fault
P0403 Exhaust Gas Recirculation Circuit
P0404 Exhaust Gas Recirculation Circuit Range / Performance
P0562 System Voltage Low
P0611 Fuel Injector Control Module Performance
P0683 Glow Plug Control Module to PCM Communication Circuit
P1378 Fuel Injector Control Module System Voltage Low
P2269 Water in Fuel Condition
P2614 Camshaft Position Output Circuit / Open
P2617 Crankshaft Position Output Circuit / Open
P2623 Injector Control Pressure Regulator / Open
The 8 "Injector Circuit Low"s and the P0611 Fuel Injector Control Module Performance are pointing me towards the FICM. Also the real-time monitoring of the FICM voltages are of concern to me but I'm not sure how to interpret them or what is out of perameters..If someone can shed some light on this info. please let me know.
FICM MAIN POWER - KOEO - 47 VOLTS
FICM MAIN POWER - CRANKING - 40 VOLTS
FICM VEHICLE POWER - KOEO - FOLLOWS BATT VOLTAGES
FICM INFO FOR SYNC - KOEO - 0 VOLTS
FICM INFO FOR SYNC - CRANKING - 1 VOLT - YES 1 (IT WAS ALSO RED ON THE PROGRAM)
I also did a KOEO Injector Buzz Test but DIDNT HERE ANY BUZZING and got the same 8 codes "Injector Circuit Low"s.
FuddleyPJones is offline
post #2 of 3 Old 12-05-2010, 11:16 PM
d and b installer's Avatar
Sounds like low battery syndrome what's your base voltage and starting voltage. Kept getting the injector curcuits low when my batteries dropped below eleven volts. Charged the batts and they went away. Just an idea.
d and b installer is offline
post #3 of 3 Old 12-06-2010, 05:19 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Quoting from your other thread...
Originally Posted by Evil Eye View Post
The SYNC is a logic code, so you will only see a 1 or a 0. Just because they are red doesn't mean that they are bad. FICM main is well below 48 volts and accompanied with the 8 Injector Circuit Low codes, your FICM is definitely bad. Like was mentioned get it replaced or repaired. Once that is done, pull codes once again because it sounds like you have other issues (2 injectors and a wiring issue)... Keep us posted.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
