Truck died need help ASAP - Ford Powerstroke Diesel Forum
post #1 of 31 Old 12-03-2010, 05:29 PM Thread Starter
legionxxii's Avatar
My GF called me said she was driving and the truck lost power so she pulled over and it died and wont start now. I have been having starting issues after its sat overnight so I am assuming it was the FICM acting up and finally took a dump. Is that what it would be? After sitting and getting it to start it would have a lack of power till it warmed up.
legionxxii is offline
post #2 of 31 Old 12-05-2010, 02:03 PM Thread Starter
legionxxii's Avatar
I got home lastnight tested FICM lowest it got was 47 while key turned on and 46 when cranking. I tore it all apart looked it over and it was fine put it back in tried starting the truck and it fired up finally after cycling the key more then 10 times. It runs REALLY rough and I have to throttle at all.
post #3 of 31 Old 12-05-2010, 02:29 PM Thread Starter
legionxxii's Avatar
Here is a vid of it idling. It isnt throwing any codes either. My gf said it was running fine then she lost power (can push gas pedal and does nothing) got it to side of rode and died. Then wouldnt start.
post #4 of 31 Old 12-06-2010, 02:10 PM Thread Starter
legionxxii's Avatar
anyone at all
post #5 of 31 Old 12-06-2010, 02:44 PM
What are you using to read codes?
Former 6Leaker owner
Newman is offline
post #6 of 31 Old 12-06-2010, 02:46 PM Thread Starter
legionxxii's Avatar
Nothing there is no check engine light on or anything. I was going to see if I coudl get a scanner but I dont know where I could rent one and see what I can find but I got sent off out of state again for work today when I was supposed to have it off.
post #7 of 31 Old 12-08-2010, 04:08 PM Thread Starter
legionxxii's Avatar
anyone at all
post #8 of 31 Old 12-08-2010, 04:27 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1074 Post(s)
Feedback Score: 6 reviews
Did your GF see any dash lights come on before it died?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #9 of 31 Old 12-09-2010, 03:54 AM
diablos30's Avatar
Quoted: 31 Post(s)
could be a few different things. unless you like throwing money at it the only way you'll know for sure what is wrong is to hook it to a good scan tool like the dealer uses or software like auto enginuity.
diablos30 is offline
post #10 of 31 Old 12-09-2010, 03:43 PM Thread Starter
legionxxii's Avatar
I asked her and no lights came on. Is there a place I can get a scan tool? Would Advance Auto rent that tool out? Or O-Rielys?
