I'm frustrated - please help
I just received my AE diagnostics equipment and was able to test the HPO system while cranking. It shot up to 1300 PSI so I think the HPO system is fine...BUT...
Where do I go from here? While I was waiting on my diagnostics program... I replaced the Crankshaft Position Sensor because it was easy, I cleaned the EGR valve, and I removed the ICP and inspected it and ohm-tested it (804) and reinstalled it. If I am getting good HPO pressure can I assume that the IPR is OK? At this point I am pretty much lost...I dont know enough about AE program to know if it can test the FICM for me or if I need to do it with a meter... From the threads I've read and the notes I've assembled I am wondering about the following: FICM - Fuel Injection Control Module ICP- Injection Control Pressure Sensor IPR- Injector Pressure Relay. It is what controls the pressure from the HPOP to the injectors PCM - Powertrain Control Module calculates the proper idle speed for conditions IDM - Injector Driver Module – Amplifies the voltage for the injectors Located in the fender behind F350 emblem. Remove fender liner to get to it. I'm frustrated - please help. |
Your high pressure oil pump is good if it builds 1300 psi and yes the IPR is good then also. My next check would be the FICM. If it is lower than 45 volts then it has failed and needs to be replaced. If you can retreive DTCs, a FICM should set all 8 injector circuit low codes and also a p0611.
Look at FICM voltage while cranking the engine.
Frustrated update...FICM info that needs decifering..
My AE program shows the following codes for the powertrain:
Enhanced Powertrain CAN P0113 Intake Air Temperature Circuit High Input P0230 Fuel Pump Primary Circuit P0261 Cylinder 1 Injector Circuit Low P0264 Cylinder 2 Injector Circuit Low P0267 Cylinder 3 Injector Circuit Low P0270 Cylinder 4 Injector Circuit Low P0272 Cylinder 4 Injector Circuit Contribution / Balance Fault P0273 Cylinder 5 Injector Circuit Low P0276 Cylinder 6 Injector Circuit Low P0279 Cylinder 7 Injector Circuit Low P0282 Cylinder 8 Injector Circuit Low P0284 Cylinder 8 Injector Circuit Contribution / Balance Fault P0403 Exhaust Gas Recirculation Circuit P0404 Exhaust Gas Recirculation Circuit Range / Performance P0562 System Voltage Low P0611 Fuel Injector Control Module Performance P0683 Glow Plug Control Module to PCM Communication Circuit P1378 Fuel Injector Control Module System Voltage Low P2269 Water in Fuel Condition P2614 Camshaft Position Output Circuit / Open P2617 Crankshaft Position Output Circuit / Open P2623 Injector Control Pressure Regulator / Open The 8 "Injector Circuit Low"s and the P0611 Fuel Injector Control Module Performance are pointing me towards the FICM. Also the real-time monitoring of the FICM voltages are of concern to me but I'm not sure how to interpret them or what is out of perameters..If someone can shed some light on this info. please let me know. FICM MAIN POWER - KOEO - 47 VOLTS FICM MAIN POWER - CRANKING - 40 VOLTS FICM VEHICLE POWER - KOEO - FOLLOWS BATT VOLTAGES FICM INFO FOR SYNC - KOEO - 0 VOLTS FICM INFO FOR SYNC - CRANKING - 1 VOLT - YES 1 (IT WAS ALSO RED ON THE PROGRAM) I also did a KOEO Injector Buzz Test but DIDNT HERE ANY BUZZING and got the same 8 codes "Injector Circuit Low"s. |
you shouldnt drop below 48v at any time. are your batteries fully charged? if so then yank out the ficm and either re-solder according to the tech article or send it out to swamps.
The SYNC is a logic code, so you will only see a 1 or a 0. Just because they are red doesn't mean that they are bad. FICM main is well below 48 volts and accompanied with the 8 Injector Circuit Low codes, your FICM is definitely bad. Like was mentioned get it replaced or repaired. Once that is done, pull codes once again because it sounds like you have other issues (2 injectors and a wiring issue)... Keep us posted.
FICM codes and repair
I am reading that it is normal for voltage drop during glow plug activation but I'm not sure about cranking...the batt voltage was low 12v high 11 v during testing didn't hear any difference in cranking... Are you supposed to hear the injectors buzz during the injector test?? 'Cuz i didn't hear squat... I've been reading up on the FICM repair - seems easy enough...The 58V upgrade seems harder...not sure if it is worth it. If the capacitors are only rated to 50v then go to 50v and avoid the other part replacements...eh? |
Repairing/Upgrading the FICM
I disassembled the FICM and can see the components but I really dont see anything obvious that is wrong with the boards...no fried componants, no cracked boards, no evidence of moisture...
Can it really be as simple as touching up a few solder joints? |
Yes, unfortunately.
