need help!!!! - Ford Powerstroke Diesel Forum
Old 12-01-2010, 02:41 PM
need help!!!!
my 350 6.0l is got a fuel leak. its leaking from around the glow plug harness where it goes into the side of the motor on the back 2 on the passenger side. does anybody know wut could be leaking b4 i go to pulling parts loose...
Old 12-01-2010, 03:12 PM
Is it leaking at the glow plugs? Your glow plugs could be loose. You would also be dumping fuel into the crankcase if that were the case IIRC. You could pull the gp harness off and check to make sure they are tight...
Old 12-01-2010, 03:22 PM
ok ima check that...what is iirc?...(sorry new to the world)
Old 12-01-2010, 03:25 PM
its leaking on the side of the block where the gp harness plugs in
Old 12-01-2010, 03:33 PM
IIRC = If I remember correctly...
You are talking about two of the four plugs on the gp line are leaking fuel on the passenger side? I'm just trying to make sure I am understanding you correctly.
Check your oil and see if it has fuel in it..
Old 12-01-2010, 03:37 PM
yea the back 2 thats where the fuel is leaking...and i checked the oil and it doesnt have anything in it....
