Need some opinions
2005 6.0 56000 miles
Problems: Really rough starts and will not run right unless fully warmed up. Driving to thanksgiving dinner and the truck has no heat, truck starts to over heat, I pull over and add a gallon of coolant.... heat comes back. However my pyro. was at 700* so she wasnt that hot. Smell of coolant in the cab....fml not again, already did a egr cooler at 36000 Truck is breaking up at WOT and at moderately pressed pedal. She is just not running smooth anymore. Oh and my turbo is crying lol This is what I'm thinking... Head gaskets are leaking and/or egr is cracked. Also think my ficm is going, or possibly glow plugs? maybe injectors? Tell me what you guys think and how should i approach this. |
rough starts and wont run right till fully warmed up. Im gonna go with Injector Stiction since thats the problem that I had with the same symptoms. Search around the forums and you will see a few different threads of people with the same problem. I switched my oil to Rotella T5 after reading a thread on it about here and I believe my truck is running better (only been 50 miles or so, could be my imagination) but dont want to say it solved my problem till I put 1k miles on it or so.
Your truck got hot and showed it was overheating on you because it was way low on coolant. Keep an eye on your coolant level cause you might have another EGR problem. It was fixed under warranty at the dealer right? There is a thread floating around that has analysis's done on the Ford Gold coolant and it appears to be the cause of the whole EGR clogging thing. I will try and hunt it down, I read too many different forums I dont remember where the hell I saw it LOL. I have to start bookmarking this stuff so I can link the threads instead of just talking out of my rear end |
Heres the thread on switching to Rotella T5 with good results in helping with stiction. 6.0 oil analysis on Rotella T-5 10w-30. You will probably like this.
Heres an interesting read regarding the Ford gold coolant and how its the cause of the gunking up of the EGR Replaced oil cooler still difference in temps Last edited by Chango; 11-30-2010 at 08:16 AM. |
I already run the Rotella it fixes the problem for maybe a hundred miles or so and the problem comes right back. Every winter the problem keeps getting worse and worse. If I have the block heater on it will start fine but the truck still needs to warm up before i can even move it. Who knows with the coolant, I got yelled at by ford for using green so I went back to gold.
Well under warranty, listen to Ford. If your out of it, you need to look out for yourself cause I can 100% guarantee Ford is looking out for themselves and can give a rats *** what happens with your truck once its not under warranty. If rotella fixes the problem for a few hundred miles that makes me think more and more it is caused by stiction. You should give Rev-X or Hotshots Secret a try. I had hotshots secret and it took care of my long warmups within 500 miles and I was able to start the truck and pull away a minute later. Its $60 -$75 which is spending alot less money than replacing injectors. Eventhough you have already switched to Rotella, grab a beer and sit down and read through that entire thread that I posted the link to. It has a wealth of information regarding stiction and what other people have done to take care of it.
You need to read through both those links for important relevant information to whats going on with your truck. The second link has great information about the coolant. This is info coming from the 100's of people who have the same problems you do Last edited by Chango; 11-30-2010 at 12:19 PM. |
