FICM Test HELP!! - Ford Powerstroke Diesel Forum
Old 11-24-2010, 04:23 PM
FICM Test HELP!!
My 06 F-250 (6.0L) cranks but will not start, and from what I've been told I have a problem with my FICM. I followed test procedures I saw on here today and tested the FICM at 48Volts. Key on/Engine off = 48V, Key on while the glow plugs are heating up it drops to 35V, then immediately back to 48V after the glow plugs heated up. Key On, Engine cranking = 48V the whole time. This makes me think the FICM is fine and perhaps it's the Cam Position Sensor. Does the fact it dropped to 35 while the glow plugs were heating up indicate a problem with the FICM? Any help would be GREATLY appreciated.
Thank you,
Paul
Old 11-24-2010, 04:26 PM
no that sounds good.
now the not so fun part. you need to be able to read real time data using something like the dealers use, such as auto enginuity, to be able to troubleshoot this engine. doing anything else is just guessing and is very expensive on these.
however, if you want a guess i guess icp,ipr,or hpo leak as those are the usual suspects.
Old 11-24-2010, 04:30 PM
How can I rule out Cam Position Sensor at this point? I understand that could be a cause and is relatively simple/inexpensive to fix.
Old 11-24-2010, 04:34 PM
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
Old 11-24-2010, 05:08 PM
Is the "Ford Enhanced Expansion" needed with this scanner? Or will the basic system tells us what we need to know about the 6.0? Thanks.
Old 11-24-2010, 05:36 PM
yes you need the enhanced, this is the cheapest place around to get it AutoEnginuity PC Scan Tool (USB)
Old 11-24-2010, 05:40 PM
Slacker
Feedback Score: 4 reviews
Sounds like you have been given some great info so far.
Old 11-24-2010, 05:47 PM
Feedback Score: 7 reviews
not to hijack but im reading dtc codes P0341 and code P0611
cam position sensor and ficm
WHAT DO I DO? and what kinda money am i looking at. my truck wouldnt start this morning and i plugged it in and started fine tonight lower 30's outside
thanks
Old 11-24-2010, 06:09 PM
thanks
Old 11-24-2010, 07:27 PM
wont that just tell me the same thing, about the 2 codes???
