06 6.0 blowing blue smoke - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-20-2010, 10:35 AM Thread Starter
6.0 stroke's Avatar
i just picked up an 2006 a few weeks ago and traded my 04 hd... well i got kinda screwed because i thought for sure the 06 would have warranty. i should have checked but it was a spur of the moment buy... another guy had 8 thousand cash to put down so i had to make my decision then and there.
any ways it a 2006 f350 lifted 6.0 bone STOCK besides the lift and tires...
the truck had 4 injectors replaced at 69000 and i bought the truck with 70000 i ran an oasis..
well the truck is blowing blue smoke ever time i start it when is cold at idle... when i warms up it will go away.. but if the engine is warm and you rev it to 3000 rpm and hold it there for a few seconds it will pour out pure blue smoke... pretty thick. it will not smoke with a load on it. any rpm
the amazing thing is that the injectors sound healthier than my 04 an the truck has lots of power and no misfire.. it runs perfect.
i guessing it needs the other 4 injectors but idk.. my main question is,, am i going to mess it up driving it around like this for a few weeks or will it be ok.
2006 F350 Lariat cc sb
ARP head studs 245ft-lb, ford head gaskets
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
coolingmist water methanol 10 gph nozzle
afe intake
intake horn
6" skyjacker 20xd hoss 37 toyo mt
stock trans
6.0 stroke is offline
post #2 of 6 Old 11-20-2010, 11:18 AM
Fox'sFord's Avatar
8oz. of Rev-x and switching to T6 5w-40 Rotella cleared it right up for me. The previous owner ever change the oil?
Fox'sFord is offline
post #3 of 6 Old 11-20-2010, 11:57 AM Thread Starter
6.0 stroke's Avatar
idk trucks form northern Wisconsin... i changed the oil yesterday to Mobil1 5-40 synthetic no rev x tho... it dose seem a bit better but not much, but the truck smokes when warm too like lots when you rev it up with no load... really think its an injector stiction problem?... seems like its on the fuel side.. smells like real rich diesel in the smoke...
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
afe intake
intake horn
stock trans
post #4 of 6 Old 11-20-2010, 12:22 PM
Fox'sFord's Avatar
Blue smoke is usually oil. Rev-x is cheap compared to injectors do a search on here about others who have used it with similar problems to yours. Mine would blow blue untill warm and switching to the synthetic and adding rev-x cleared it up within the first 100 miles. You might also want to check your to see if your turbo is leaking oil, pulling your down pipe is an easy way to check.
post #5 of 6 Old 11-21-2010, 06:33 AM
Slacker
Evil Eye's Avatar
Quoted: 192 Post(s)
Feedback Score: 4 reviews
I would check your turbo to see if it is leaking oil. That's exactly what mine is doing and now I'm waiting on my Powermax!
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 6 Old 04-05-2011, 02:45 PM
diablos30's Avatar
Quoted: 31 Post(s)
do the powermaxes have the same issues as the stock turbos (sticking vanes, blowing seals)?
diablos30 is offline
