Up-Pipe / Y-Pipe leak - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-18-2010, 09:00 AM Thread Starter
nylyon's Avatar
Since I've owned my truck, I suspected that I had an exhaust leak under the hood. I haven't reached my hand up in there to feel around the various joints, but I am "assuming" that it's the flex joint on the y-pipe. I assume that because the leak was present before the turbo was removed for the first time in May of this year and I have smelled exhaust in the cab since I bought the truck used in 2008. I am planning on fixing this in the spring of 2011, but I do have some questions.
This is my first and only powerstroke I have no baseline experience. Would the exhaust leak be responsible for any of the following concerns that I have:
1. Exhaust smell in the truck (kind of a no brainer on this one)
2. Maximum boost on the insight gauge shows 21 psi
3. Sluggish take off *when warm* no way will this truck spin the tires.
4. Cold start issues (FICM was just checked 47.9V key on engine off, 48.1 engine running 48 degrees ambient) Rev-X cured this last year.
5. Louder under hood engine noise that I have seen on other power strokes
6. I do hear a ticking sound under the hood. I could have an injector issue (see #4).
I am planning on fixing the issue in the spring, but purchasing a new y-pipe, and I am told that the pipe which connects to the EGR cooler doesn't often fail at the flex joint (not that it isn't the issue, I will check all of that).
Oh, it's a stock 2003 6.0 Rotella T5 (changing to T6 on Sunday for the winter)
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #2 of 8 Old 11-18-2010, 09:36 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Karl,
I would agree with your assessment that most all of those symptoms sound like a broken flex joint. It may be your y-pipe or it could also be your up-pipe (which you mention), which I would suspect first given the low amount of boost and in my experience is far more common. It is also easier to check since there is a little bit more room.
PS. The y-pipes were prone to failures on the 7.3's since they didn't have a bellows to allow them to flex, which caused cracking and breaking.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 8 Old 11-18-2010, 09:59 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
YES
YES
YES
Sticking injector(s). Requires diagnosis using Ford's IDS with the power balance screen loaded up during cold engine start-up to pinpoint.
YES
It depends on the type of "ticking". Without actually hearing it, I don't want to comment on what it might, or might not be.
The right side y-pipe is what fails most frequently on F-Series. I have only ever replaced one right side EGR cooler flex pipe on a very high mileage E-Series.
Answers are in bold red.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #4 of 8 Old 11-18-2010, 10:13 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Interesting observations. Looks like I was wrong concerning the up-pipe.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #5 of 8 Old 11-18-2010, 10:16 AM Thread Starter
nylyon's Avatar
You do mean left side Y pipe right, the one which is the difficult one to replace.
Thank you for the replies, now I'm looking forward to the spring. Since replacing the oil cooler twice and aside from this exhaust leak and possible related concerns, this is such a great truck, and I have had no other issues with it. Of course the cold start issue is probably a sticky injector or 2, but we'll get there....
Edit: And I hope that this doesn't become near the adventure the oil cooler was
- Karl
nylyon is offline
post #6 of 8 Old 11-18-2010, 08:20 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
You are correct, I meant to say DRIVER side y-pipe. My mind was a little off. I was in the middle of buttoning up an E-Series for both coolers when I replied. Sorry.
No offense intended, but I honestly don't know how you can call it a GREAT truck with the issues you've been having. To tell you the truth, every time I get one these trucks in when they're out of warranty, I cringe at the thought of what the customer has to pay for my services, to repair their truck.
m-chan68 is offline
post #7 of 8 Old 11-18-2010, 09:25 PM
dusthol's Avatar
is there an aftermarket pipe? i cant believe the price on the pipe from ford.
dusthol
dusthol is offline
post #8 of 8 Old 11-19-2010, 03:51 AM Thread Starter
nylyon's Avatar
No offense taken. Although I have had a problematic oil cooler, and a possible crack in the y-pipe, I bought the truck for cheap, it drives beautiful, pulls hard and hasn't left me stranded yet. I grew up in a family who owned a trucking company. Maintaining vehicles is important, and repairs on heavy service vehicles are expensive. Now, I'm sure if I wasn't able to perform the labor myself, I might not feel the same.
- Karl
nylyon is offline
