testing glow plugs - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-12-2010, 08:40 PM Thread Starter
strokethis04's Avatar
Quoted: 3 Post(s)
testing glow plugs
Hey guys I was woundering what is the easiest way to test the glow plugs in my 6.0l. And are the glow plows under the valve cover or on the outside of it? it was only 28 here today and i didn't want to start this morning
Thanks Jeff
2004 f-350 cc 6.0l
afe stage 2
4in magnaflow
sct with looney from dj
6 inch lift
33x15.5 mt atz
16x10 raceline renegads
zoodad
auto meter gauges
strokethis04 is offline
post #2 of 4 Old 11-13-2010, 03:10 PM
check for DTCs first. usually if you have a bad glow plug, it will throw a DTC, but may not set the check engine light. Glow plugs are outside the valve cover. Takes about 20-30 minutes to change out the driver side, labor guide says 4 hours for the passenger side, all depends on motivation i guess lol. Also check your glow plug relay. They are pretty common on these engines and fairly easy to test. Connect a test light between the battery and the big terminal on the relay that the battery cable is going to. With the key on, engine off, the test light should illuminate. Hope this helps.
firefighter317 is offline
post #3 of 4 Old 11-13-2010, 06:45 PM Thread Starter
Quoted: 3 Post(s)
Yes it helps thanks for the response I found in the tech section how to test them. I didn't know if a glow plug was bad if it would throw a code so I will scan it. But also I didn't think th 6.0l had a glow plug relay do you know where it is? but now that i think about it last fall I had the same problem and it was the FICM so i will test that too. But I don't know if I'm going to try and fix it my self or not my boss works on little sewer cameras so i think he can solder it for me
Thanks Jeff
2004 f-350 cc 6.0l
afe stage 2
4in magnaflow
6 inch lift
33x15.5 mt atz
zoodad
auto meter gauges
post #4 of 4 Old 11-14-2010, 02:09 AM
Something to bear in mind is a glow plug can test out ok electricaly but still not be working correctly. Heavy carbon buildup on the electrode will rob the efficentcy of the plug. Most of the heat generated will be absorbed by the carbon and will not reach the cylinder and block.
I recomend pulling and cleaning glow plugs at least once a year if the truck idles a lot.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
