Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 04-29-2006, 05:44 AM
timmy timmy is offline
coolant leak
hey guys, I'm sure this has been covered prior but I cant find anywhere. I seem to be blowing coolant out of my overflow bottle after the truck has been shut down. Doesnt seem to be a whole lot but enough to concern me. I did a head gasket test on it and it showed a minor trace of CO. The truck has never overheated, never even gets that hot. Just wondering if this was a sure sign of headgaskets or hopefully something else. One more thing...with so many doing headgaskets and going to ARP studs, does anyone make a better gasket?
Old 04-29-2006, 07:22 AM
mschn99 mschn99 is offline
if its not overheating i would probably be more suspect of the EGR cooler or a restriction in the cooling system, especially when it does it only on shut down. for that matter it could even be as simple as a weak cap.........Marc
Old 05-04-2006, 02:10 PM
Jon
Tournaments Won: 1
Posts: n/a
Timmy
Im not sure what year your 6.0 is but there is a recall out on that same issue. I don't have the number right off hand but Ford relized that the full line on the over flow bottle was to high so we put a sticker on there with a new line and suck about a quart or more out to keep it from overflowing.
