6.0 low boost - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-11-2010, 02:22 PM Thread Starter
powersmoker99's Avatar
6.0 low boost
havee a 2003 6.o powerstroke truck is all stock except the 5 inch exhaust and the hpop and injectors are 1 week old ever sesne then i can only get 21lbs of boost and before the hpop i could get 30 psi i put my boost leak dectoector on it and put it to 15psi and could not here feel any leaks what kind of boost should i see
powersmoker99 is offline
post #2 of 15 Old 09-13-2010, 05:00 PM
Is it down on power?
Newman is offline
post #3 of 15 Old 09-15-2010, 10:27 PM Thread Starter
seems to not have as much power as with the old hpop but i cant find a boost leak i dont no what it is fustrated but im still get 14mpg in the city
post #4 of 15 Old 09-16-2010, 06:11 AM
optimus's Avatar
try unplugging the turbo and plugging it back it a couple times with the engine running i have had to do this a couple of times after installing a new HPOP its almost like the PCM gets confused and need to be reminded it has a turbo. I'm not sure why but it has worked for me.
If your not giving your all at everything you do your just slowly failing
MY TRUCKs
2002 F250 crew cab short box 4X4 7.3l
E99 F350 dually PSD 7.3 EDGE EVOLUTION running perfect thanks to and engine from NOTSTOCK
^^^don't run your 7.3 with a bad injector this is the result^^^
optimus is offline
post #5 of 15 Old 09-16-2010, 07:18 AM
If they had the batteries disconnected for more that 4 hours, you may need to perform the following VGT relearn procedure:
KAM (keep-alive-memory) reset & VGT learn procedure
1. Drive the truck until the engine and transmission have reached normal operating temperature.
(The VGT learn procedure requires that the oil and coolant temperatures be at normal operating temperature)
2. Flash truck back to stock (Only need to do this if running a tuner or module)
3. Turn on the headlights
4. Disconnect both batteries
5. Short out + to - battery cables to each other (Make sure both batteries are disconnected before doing this).
6. Let truck sit like this for 10-minutes
7. Turn off the headlights.
8. Re-connect batteries
9. Cycle the key to the run position twice. Pause in the “ON” position each time until the wait to start lamp goes out (minimum 5-seconds) and pause in the “OFF” position each time for 10-seconds to be sure the PCM has "gone to sleep".
10. Start the truck and let it idle for a minimum of 5-minutes at normal operating temperature. This allows the PCM to learn the EGR valve closed position value. Also you will likely hear the turbo pitch change several times during this period as the PCM learns the necessary duty cycles for accurate VGT control.
11. Complete the road test Drive Cycle:
15 miles of mixed driving (*should* be enough in most cases) to allow the PCM to "re-learn" its adaptive strategy.
Note: Anytime the batteries are disconnected, the PCM will throw the P1000 code until the “Drive Cycle” is completed.
'15 F-350 CC 6.7L
steelhorse83 is offline
post #6 of 15 Old 09-16-2010, 02:21 PM Thread Starter
all try that and now an injector went out truck shakes like a sun of a gun at idle and missis through the rpm range im sure this was part of the boost problem not enough fuel for proper boost and all try the re-learn
post #7 of 15 Old 09-17-2010, 09:20 AM
optimus's Avatar
it may not be an injector causing the vibration if the turbo is not functioning properly it can give the same symptoms try the VGT relearn procedure and see if that helps you
MY TRUCKs
optimus is offline
post #8 of 15 Old 09-22-2010, 11:17 PM
I am having low boost above 2000 rpm. I changed fuel filters and performed the VGT relearn procedure. ran around a few places and for the first hour or so had all the boost .. then when I did a freeway trip. low boost above 2000 rpm was back. not as bad but still there. I have new all new injectors and new FICM and now this damn problem. any one have any ideas how to fix it?
6.0 international suck is offline
post #9 of 15 Old 09-27-2010, 04:14 PM
Have you cleaned your EGR valve?
Newman is offline
post #10 of 15 Old 09-28-2010, 08:37 AM
I cleaned the ERG valve about 1000 miles ago. just put new fuel filters in.
I get all the boost at High RPM ,,its just in the 1800 to 2000 rpm range.
Is there any way to by pass the ERG Valve?
