6.0 Cylinder fills with fuel, consistant raw fuel out the tailpipe - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-18-2010, 08:25 PM Thread Starter
Spinal Tap's Avatar
Any help would be appreciated. Truck was made 8- 2003
Truck has 486,000 on it (6.0) and when the truck sits for awhile it hardly cranks over because 1 (or more) cylinders fill with fuel. Fires up eventually after letting it sit.
Let it sit for 1 1/2 hours fuel does not get into the cylinder, and cranks up just fine since its not trying to compress a liquid. Still dumps raw fuel out the tailpipe
Raw fuel coming out the tailpipe all the time, but it runs and drives. Looks like white smoke and some black smoke mixed together. This is at a idle, did not bother revving it up. Guy i purchased it from says he just drove it back 250 miles getting 6mpg.
Engine oil is dark, not excessive, looks like normal used oil, does not smell like raw diesel, no fuel in crankcase from looking at it...
Slight miss, id have to spend more time with it to get all the particulars.
So, id asssssume it has a stuck open injector, or a bad o-ring on some injectors.
Could i pull the glow plugs and crank over the engine and see where it comes from to help pin point the bad injector??
Would the EGR cause the truck to dump raw fuel into the motor? Cracked intake manifold?
I do not have a scanner currently, can i use a horsepower box to try and pull codes? I have access to a hp box,,, superchips?
I also have a 7.3 psd with no issues, i am familiar with diesels, just not a whole lot with the 6.0 ....
Links, hyperlinks and plain english (no acronyms please)
I will buy someone a STEAK AND LOBSTER DINNER if we can fix it
Thanks for your guys help.
BRYAN
Spinal Tap is offline
post #2 of 18 Old 07-18-2010, 08:34 PM
powerhoghp's Avatar
Yep, a stuck injector or injectors.... I would do a contribution test to see which cylinders stops the constant stream of fuel. Then look in the cylinder with a bore scope through the GP hole for damage. Then replace the injector. You got ALOT of miles out of those injectors.... Please try not to run this truck until you get it fixed as the excess fuel can melt the pistons and destroy the valves... the superchips tuner, if it can pull codes would help diagnosis quite a bit too.
powerhoghp is offline
post #3 of 18 Old 07-18-2010, 08:42 PM
Only an injector issue will dump fuel into a cylinder or a head issue [you do not seem to be running hot enough to unseat the heads] so I would go with injectors. The glow plugs work well for locateing the cylinder/s affected pull em and roll her over and see where she spits. As a side note ya can have a bad injector in this situation and show no codes unless the scanner can show a cylinder misfire from cylinder contribution.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 18 Old 07-18-2010, 08:50 PM Thread Starter
Spinal Tap's Avatar
Thank you guys, ... Sounds like ive got my hands full.
I will search what a contribution test is and how its done...
I havent driven it, hopefully not too much damage yet.....
Hopefully, i was just reading and seems like i can do this at work tomorrow.
"Sounds like the classic 6.0L injector stiction issue, Another quick and easy test you can try yourself, is to remove the secondary fuel filter and fill up the housing. Crank the engine over with the key out of the ignition, by using the jump starter on the passenger side of the engine, and peak inside the secondary fuel filter housing for the presence of bubble(s). If bubbles appear, it means you have compression gases leaking into the fuel system. "
Thanks
BW
BRYAN
post #5 of 18 Old 07-18-2010, 09:13 PM
486k? WHOA! im sure that things on its 8339439 egr cooler.. headstuds? definitely replace them injectors!
Dietoremain is offline
post #6 of 18 Old 07-19-2010, 08:27 AM Thread Starter
Spinal Tap's Avatar
OK i pulled the codes p0272
Thats number 4 cyl what side is number 4 on this ford?
Drivers side 2nd back from the front?
BW
BRYAN
post #7 of 18 Old 07-19-2010, 11:44 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Here you go:
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 18 Old 07-19-2010, 11:53 AM
willholl79's Avatar
That's the most miles I've heard of on a 6.0. Any idea on the history of the truck?
2005 F-350 CC LB 4x4 XL 6.0
SCT
4" Turbo back exhaust
03 turbo
Studs
Coolant Filter
Warren Stock+ injectors
1996 F-250 ECLB 4x4 XLT 7.3 Auto
1993 F350 CCLB 4x4 5spd 7.3 NA
willholl79 is offline
post #9 of 18 Old 07-19-2010, 12:19 PM Thread Starter
Spinal Tap's Avatar
[QUOTE=Evil Eye;1986991]Here you go:
[/QUOTE
You forget the hyperlink????
Please repost what you were thinking of, thanks bud...
History of truck, it used to be owned by a guy who drove it alot
I just purchased it broken. Hoping to get it running and possibly hit 500,000 miles would be neat.
BW
BRYAN
post #10 of 18 Old 07-19-2010, 12:43 PM
willholl79's Avatar
Have any idea if it's the original motor or not?
SCT
03 turbo
Studs
Coolant Filter
