limp mode while towing - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-09-2010, 06:01 PM Thread Starter
I recently bought a 2005 F250 with about 80,000 miles on it, very clean one owner truck. I bought this to pull my camper with. On our first trip it was doing great until I started up a mild grade at about 70 MPH. It geared down and was doing good and then it upshifted and the wrench light came on. At this point of course it started to slow down and got down to about 60 MPH. I pulled off at the first opportunity and checked all the obvious stuff and everything looked good. I cranked it back up and the wrench indicator was out and it did fine until I ran up on another grade like that. It runs fine while I'm not towing but that's what I bought it for and by the way I was in the Tow Mode. If anybody has any ideas how about help me out.
RJ 6.0 is offline
post #2 of 11 Old 07-09-2010, 06:04 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Fluid levels good and everything?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 11 Old 07-09-2010, 06:09 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
What were your RPM's?
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #4 of 11 Old 07-11-2010, 07:26 AM
Welcome to the real world of Ford! Same thing here, so far I have have replaced the oil cooler, EGR valve and now the Ford Dealer says it could be a fuel problem or most likely rust in the turbo.
Laredo06 is offline
post #5 of 11 Old 07-12-2010, 04:24 PM
I win....
cRaZy8's Avatar
Quoted: 47 Post(s)
Garage
Search for my topics/threads. We have one going on this issue. Codes P0299 and P0234. Dirty turbo/ unison ring. Mine is coming apart this weekend.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #6 of 11 Old 07-12-2010, 05:39 PM Thread Starter
Fluid levels were good and RPM's were 2800-3000. I appreciate the replys I'm just trying to get an idea of which direction to go.
RJ 6.0 is offline
post #7 of 11 Old 07-12-2010, 06:29 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Are you getting any DTC's? What is your ICP, ICP desired, and IPR duty cycle when you pull the hill. Also what gears are you running? 3.73's with oversized tires will cause you problems when towing up a grade...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 11 Old 07-13-2010, 02:39 PM
Just overload the guy with questions...
You need to buy a good code reader with advanced Ford software. Its a investment you won't regret.
Newman is offline
post #9 of 11 Old 07-13-2010, 02:58 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Well, aren't they good questions?
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #10 of 11 Old 07-13-2010, 05:57 PM Thread Starter
They are good questions, just didn't know I was going to have to buy support equipment to go along with the truck. Took it to the dealership and they said it had no codes stored. If you guys got any recomendations on a good reader at a reasonable price I would appreciate it.
RJ 6.0 is offline
