Injector Pulse Width drops to zero.... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-26-2010, 04:09 PM Thread Starter
I just finished studs, oil cooler, and egr delete. The truck will fire right up and idle. Sometimes it hiccups, but usually good at idle. Then when I let off the pedal(no load while driving) the injector pulse width bounces to zero and back. Truck stays running, but acts like it runs out of fuel. NO Codes. Can this be air in the lines still. Have about fifty miles on it and 20 minutes of idling.
1/2 Ton Gasser
05' F-250 (SOLD)
Studded
SCT tuned by Gearhead(SRL+)/Insight
AFE intake
MBRP to 6'' stacks
2'' Leveling Kit
Zoodad
Kitty,EGR,muffler gone
"If an eagle had thumbs it would carry a gun"
MMC(SS) Jeff Mejia
skeeter60 is offline
post #2 of 8 Old 05-26-2010, 04:19 PM
What are you useing to see pulse width, an ociliscope?
As far as the air, running that long any air from when the system was opened is long purged out. That does not mean you may not be sucking in air from somewhere else.
Can you get any live data readings?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 8 Old 05-26-2010, 04:23 PM Thread Starter
The Insight can read it.
1/2 Ton Gasser
05' F-250 (SOLD)
Studded
AFE intake
MBRP to 6'' stacks
2'' Leveling Kit
Zoodad
MMC(SS) Jeff Mejia
post #4 of 8 Old 05-26-2010, 05:12 PM
ahhh ok does it also read live data to see if any signals are cutting out when your problem occurs, like fuel pressure suddenly droping or oil press. etc
post #5 of 8 Old 05-27-2010, 04:39 AM Thread Starter
Ya it is reading live, but I am still playing with it. Don't think I can measure fuel pressure or HPOP pressure.
1/2 Ton Gasser
05' F-250 (SOLD)
Studded
AFE intake
MBRP to 6'' stacks
2'' Leveling Kit
Zoodad
MMC(SS) Jeff Mejia
post #6 of 8 Old 05-27-2010, 09:41 AM
Pretty sure injector pulse width should go to zero momentarily when you let off the throttle. When you are going downhill with the converter locked you can hear the injectors stop firing if fuel is not needed to maintain RPMs.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #7 of 8 Old 05-27-2010, 12:03 PM Thread Starter
Ya you're right. I changed the oil in it today before I took it to the dealer and it is running like a champ. I didn't have the Insight in it before the head stud job so I didn't remember what it ran like. However, I put cheap 15-40 dino oil in it just to run for a few miles and change to help clean all the crap that might have gotten into the motor. Truck ran like crap as stated above. When I put the Mobil One Syn 5-40 back in she purrs like a kitten.
DON'T RUN CHEAP OIL.
1/2 Ton Gasser
05' F-250 (SOLD)
Studded
AFE intake
MBRP to 6'' stacks
2'' Leveling Kit
Zoodad
MMC(SS) Jeff Mejia
post #8 of 8 Old 05-27-2010, 01:13 PM
Yup and use motorcraft filters as well.
