I bought a 2003 f450 with the powerstroke 6.0 and on the way home it would go about 15 miles and lose power giving off a god awful clanking sound from the engine. it shut down and you can let sit for about 15 mins and fire up and drive somemore. The check engine light was on and when i scanned it it read the Injector control pressure sensor was low. Also i took it to a ford authorized shop and they did what they call a deepscan and it pulled about 4 codes which are as follows.P0263 which was the #1 injector,P0480 cooling fan control circuit, P2285 ICP low-PCM bad, P1284 ICP failure, no voltage to ICP. Any help with this matter would be greatly appreciated, I just would like to get this baby back up and running right. Thanks
