05 6.0 air in fuel need some help please - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-12-2010, 08:11 AM Thread Starter
So i had a dumb *** attack when i changed my fuel filters this weekend. I didnt get the cap on the bottom filter all the way tight for some reason. Anyway i drove it and well i could definantly tell there was air in my fuel. How should i go about bleading the air out??
wisemind2 is offline
post #2 of 5 Old 04-12-2010, 08:29 AM
purplehorn1977's Avatar
make sure the cap is tight and then cyle the key 5 to 6 times and let the fuel pump run till it stops each key cycle. thats about all you can do then start it and go drive it. this will bleed the rest from the system.
2004 F250 6.0 CC 4x4 SCT with custom tunes
zoodad mod, head studs, Home Brew EGR delete, 5" MBRP striaght exhaust, 05 headlight Conversion
HID Head and fogs.
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. Jon Roland, 1976
purplehorn1977 is offline
post #3 of 5 Old 04-12-2010, 01:27 PM
You may want to make shure you didn't damage the o-ring cover gasket.
dannyboy950 is offline
post #4 of 5 Old 04-12-2010, 02:09 PM Thread Starter
so just run it even though its running not so great... Im sure the o ring isnt hurt i just didn't tightnen it all the way cause im an idiot.
post #5 of 5 Old 04-12-2010, 04:54 PM
Feedback Score: -1 reviews
yes, your going to need to run it to bleed the air out of the fuel rails and lines ect. cracking open the secondary fuel filter cap will help, but your going to have to take her out for a spin
fordmasterdieseltech is offline
