EGR and Oil cooler help
So I have to replace my EGR cooler and Oil cooler. I have a guy that will do the work for me to help save some money but I just have a few questions
1) I want to do the EGR delete. There seams to be a pretty big range of cost for the kit. Can any one steer me in what kit is the best. Also I have been told I might have to turn the EGR sensor off if I do the delete kit. Is that true. If you don't turn the EGR sensor off will that trip the check engine light.
2)whats a good oil cooler to get. I don't have the money for the by pass kit. I'm looking for some easy to install but will hold up better them the OEM
3)should I get an coolant filter kit installed at the same time I'm doing all this work.
