EGR delete pros and cons? - Ford Powerstroke Diesel Forum
Old 03-16-2010, 04:36 PM
Question EGR delete pros and cons?
I also have this thread posted in the general discussion, Just dont want you all to think Im advertising or somethin.
A friend of mine has an '03 F250 cc 4x4 6.0L auto, The EGR went bad and he is considering getting a delete kit for it.
Just curious if anyone on here has any input on the pros and cons? Does it effect the longevity of the engine?
The kit they looked at was from bulletproofdiesel.com $1600
A local diesel Mechanic told him that he could delete it/ bypass it for $600 and didnt need a whole kit? What he meant by that I have'nt a clue? But apparently he can do it, and a guy I spoke with had it done by him and is going on 4 months now.
Your input is greatly appreciated! Thanks - Drew
Old 03-18-2010, 09:01 AM
Send a message via ICQ to VeeDubTDI Send a message via AIM to VeeDubTDI Send a message via MSN to VeeDubTDI Send a message via Yahoo to VeeDubTDI
You should absolutely delete the EGR and EGR cooler. It will greatly improve the longevity and reliability of your engine. When you do the EGR delete, make sure that you replace/rebuild your oil cooler, as it will likely be clogged with crap from the cooling system.
Old 03-18-2010, 05:17 PM
Feedback Score: 5 reviews
EGR Delete kit is the way to go and really there are no Cons to a delete kit
Old 03-18-2010, 05:41 PM
I think mine went out today. Will Ford do this for you. Just to let you know this is my first diesel truck and I've only had it a month. 2006
Old 03-18-2010, 06:14 PM
Ford typically will not install EGR deletes.
Old 03-19-2010, 05:58 AM
The only con that I can possibly think of is that it will make the truck take a little longer to warm up in the winter time, but that isn't really a big deal. Also, it will increase your NOx emissions.
Old 03-20-2010, 01:32 PM
Feedback Score: 9 reviews
Bulletproof Diesel does not offer an EGR delete, they offer a better version of the EGR cooler for $375. The OIL COOLER they sell is $1600. A good EGR Delete will range from $250-$600.
Old 03-21-2010, 06:22 PM
We offer a delete also. We just don't push them.
Old 03-22-2010, 04:09 PM
I have a 05 f-350 6.0 dieesel Can I just get a used egr cooler and weld the ends and by pass coolant.Need some help thanks
Old 03-22-2010, 04:32 PM
You can. You need to be able to weld stainless steel. And you also need to make sure the material you add is thick enough.
It will turn on your check engine light and if you do it wrong, you could mess up your 6.0. We get a few of those here every now and then.
For the record.... This is the WRONG way to do it.
