Pukeing
Truck went into ford monday, called today and was told they took off the EGR cooler and tested it , check out ok. now they have to tae the motor out to replace the head gasket. I then asked if I was to give them the stronger head bolts would they be able to install them. I was told that the ford head bolts are upgrades from the factory installed ones that failed.Is this True?There is only 34,788 miles on the truck.
Yes they are stronger than the ones from the factory. Are they strong enough, NO
so it pays to have the ARP studs installed . Thanks for the heads up. I have a feeling that they will say the warranty will be voided. will see.
You for sure want the ARPs in there.
ok I'll order them. where is the best place to get them?. Thanks
browns diesel
definetly step up to the arp studs. they should install them, but its up to each dealer if they will undewr warranty.
thanks for the info guys. will check it out.
i got my heads studded...and now i believe my head gaskets are blown
I have seen that before.Usually best way to do them is pull the cab off.I've seen them go when the cabis left on.You need some room to torque those studs.
