no power, vibration
hi, new to forum , i have a problem with a 03 ford f350 6.0 126,000 miles.the problem is when you get on it hard it don't have the power it use to and it has a wierd vibation,when you put and skidloader behind it the vibration gets worse,it only does it from 2400-3500 rpm it vibrates all the way up the seat,if you let off the gas it goes away. no codes ,runs great all the other times,new heads,headgasket,egr cooler and head bolts. it also has new hanger bearing. any info would be greatly appreciated. thanks ,jason
