6.0 degas bottle - Ford Powerstroke Diesel Forum
Old 03-15-2010, 04:52 PM
6.0 degas bottle
working on a 2005 6.0 w/ 104k has a chip bolw coolant from degas bottle w/ or w/out chip pressure tests leaks down 5psi in 20mins no white smoke from tailpipe egr cooler not leaking could this be headgaskets and what is a good way to tell forsure?
Old 04-24-2010, 10:06 AM
Powerstroke Techie
Head gaskets probably. Tee- in a gauge and monitor cooling system pressure, an ECT and EOT. Check if the ECT/EOT is within 15 degrees. If not, repair that first. If it is, and you are getting 16psi pressure in the cooling system, it is likely a head gasket leak.
Check all other coolig system components for leakage, restriction, and proper operation first.
Old 04-25-2010, 04:39 AM
I am inclined to an external leak, if it was getting into the combustion process
it would show smokeing signs from exhaust. You state there is no smoke issues.
Follow the aforementioned test procedures. Check your test equipment and connections aren't leaking giveing you a false reading. Look for external signs of water leakage at all connection points, also along the edges of the heads. Check for water in the oil/pan. If you are looseing water it has to go somewhere.
Also bear in mind the earlier degas bottles were mislabled for water level.
A manufacturer error.
What are the exact test pressures you are useing, bear in mind the 6.0 uses a low water pressure system, it is not like the old systems that had in some cases a 30 PSI operateing range, if you pump it up too far past the cap rateing you will show a rapid pressure loss untill the system stabilizes.
Last edited by dannyboy950; 04-25-2010 at 04:46 AM. Reason: after thought clarification
Old 05-23-2010, 11:53 AM
[QUOTE=dannyboy950;1853074]Also bear in mind the earlier degas bottles were mislabled for water level.
QUOTE]
Any idea what dates were considered early for these mislabled bottles?
Thanks
Old 05-23-2010, 12:11 PM
I haven't pressure checked mine, but I'm still losing coolant and I don't have white smoke either. Subscribing.
Old 05-23-2010, 12:21 PM
Cool
[quote=artsamm;1903026]
QUOTE]
Thanks
Mines a 2005 and was mislabled new sticker lable been on it forever.
Just blows when over filled.
JE-1
Old 05-23-2010, 02:22 PM
The 03's were misslabled from the gitgo LOL it just took em a while to figure/admit it and I think mid 04 to late 04 is when they started issueing the little sticker.
I remeber a TSB to tell people to keep the level just above the low mark until the stickers were sent out.
