Fuel Locking the cylinder - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-12-2010, 06:14 PM Thread Starter
sweetdeeillusion's Avatar
I have an 03 early build 6.0. It lost one injector at all times and was skipping on two when cold. I replaced all three injectors, 3-2 and 8. Started good. Ran about 4 miles and felt like it ran out of fuel. Stopped and restarted. Ran quarter of a mile and did the same thing. This time motor was locked solid. Pulled codes found 1 and 7 contrib codes. Assumed new injector on that side was at fault. Pulled injector, still solid pulled 1 and then 5, boom cloud of fuel.
Replaced #5
Ran for about two mins and same happened again. Pulled 1,3 and 5 no fuel. Pulled 7 no fuel obvious but lock gone. Got supplier to swap out new injectors. Refit same again !
Help what is going on. Going to replace 7 tommorow as a long shot. I changed all seals each refit. No fuel in oil or coolant. Does not lock till truck has ran for a couple of mins.
Found out the problem is an injector cup. I hope !
DRIVEN TO DISTRACTION BY FIX OR REPAIR DAILY
Love my truck, but hate the reliability. Love the look of the 2011 if its RELIABLE
Certified Detroit-MBE, Cummins and CAT Diagnostic/Drivabilty and Electonics Tech.
05 Ford F350 6.0 King Ranch Crew Cab Dually FX4
03 Ford F250 7.3 Lariat Crew Cab 4X4
EGR Deleted
sweetdeeillusion is offline
post #2 of 8 Old 03-13-2010, 08:07 PM
Feedback Score: -1 reviews
I would recheck all the injectors you replaced orignally, sounds like you cut an o-ring on one of them.
fordmasterdieseltech is offline
post #3 of 8 Old 03-14-2010, 04:42 AM Thread Starter
I pulled all the glow plugs and found # 8 was the culprit. Pulled the injector and found the bottom o ring blowing by. Replaced the o ring and with just fuel pump running it refilled the combustion chamber with fuel. Checked the injector,could not see any faults so changed the injector. Same thing, I am thinking the cup is some how damaged. I am not sure but think I can change the cup without pulling the head. Tried researching on line and found a guy selling a tool.
Makes sence of the way it failed. I torqued down the injector, but either I already had a faulty cup or I did not seat the injector somehow correctly. I can only assume that pulling the injectors on the RH side released enough compression to allow the starter to compress and blow out the fuel in #8. The fuel disposed by #5 was drop compared to the amount that came from #8.
EGR Deleted
post #4 of 8 Old 03-14-2010, 04:59 PM
does the truck start fine after it has set for a while & after a few minutes of idle starts smoking like crazy i helped mechanics change injectors on an 03 twice where i work same symptoms ended up being busted injector sleeve on the #5 cylinder
cain6.0 is offline
post #5 of 8 Old 03-14-2010, 06:20 PM Thread Starter
Exactly what it did. #8 for me tho.
EGR Deleted
post #6 of 8 Old 03-15-2010, 04:47 PM
the injector sleeve can be changed without pulling head the truck i was telling you about, we put two full sets of injectors in it before we found the busted sleeve
cain6.0 is offline
post #7 of 8 Old 03-16-2010, 02:13 PM Thread Starter
Made the extractor and installer today. Got the sleeves, as Ford calls them, today also, $2.16 for 4 ! Going to fit it tonite.
EGR Deleted
post #8 of 8 Old 03-16-2010, 02:33 PM
troid123's Avatar
Send a message via AIM to troid123
subscribing, good luck I hope this fixes the problem!!
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
