Oil leak, amongst other things... 2006 PS
I have had a noise coming from the left front for the last coouple days (grinding/dragging noise on take off and turning, stops or subsides when brakes are applied). Anyways, I crawled under to see if anything was loose, obviously damaged, and noticed oil on the bell housing. Not alot, but enough to cover my finger. There is a rubber grommet right above it, maybe an inspection port of some kind?, and when pressed on, I can see oil seeping around the edges. I thought about pulling the grommet off, but decided against it. It is engine oil, to tranny fluid. Any thoughts?
