TURBO SOUNDS LIKE JAKE BRAKE - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-10-2010, 07:54 PM Thread Starter
I bought "forina" a 2005 6.0 crew cab with 26000 miles and now she has 80,000. From the time I got her whenever you get into the throttle and then let off it sputters like a jake brake on a big truck. It sounds like some kind of blow by that can only escape when you let off the throttle. Ford dealer told me i need a new turbo but then said they couldn't replace it under warranty because the computer didn't say it was bad. Of course now the warranty is expired and the local dealer has no clue what is wrong. I've been told that it sounds like the waste gate isnt opening properly, and I've been told that's not possible because I dont have a waste gate. Please help
forina is offline
post #2 of 8 Old 03-10-2010, 08:24 PM
Gforce33's Avatar
Turbo Fart? Does it do it just for a second or two after you let off on the throttle? If so, that is normal.
2005 F350 Kingranch FX4 Dually
6.0L Diesel,
Elite/Liberator EGR Delete.
K&N Stage II Intake.
4" MBRP Turbo Back Exhaust, Kitty Gone
2003 International Turbo.
SCT X3 SRL Tune by Matt @ Gearhead and ID's tow and street via Adam.
3 Gauge pillar W/pyro, trans and Boost
Gforce33 is offline
post #3 of 8 Old 03-10-2010, 09:24 PM Thread Starter
yeah its only a couple of seconds. kinda like chu chu chu chu. the other thing that it does is when you get into the throttle and then let off... when you try to accelerate again it wont boost. it will make a muffled bogged down sound and wont get up and go until you let completely off the throttle for a second and then try again.
forina is offline
post #4 of 8 Old 03-10-2010, 09:34 PM
Gforce33's Avatar
The chu chu chu chu chu is normal. The other problem I am not so sure about.
6.0L Diesel,
Gforce33 is offline
post #5 of 8 Old 03-11-2010, 05:36 PM
ajpu1983's Avatar
I would clean the turbo and if the problem persists it could be your VGT solenoid.
ajpu1983 is offline
post #6 of 8 Old 03-12-2010, 08:35 AM
rocky1074's Avatar
I agree with ajpu1983 about cleaning the turbo..
Diesel Technician Society
2003 F-350 SD 6.0 Crew Cab DRW
Dieselsite Coolant Filter; High Idle mod.
24" Windshield Wipers; Prodigy Brake Controller;
Fumoto Valve; ZooDad Mod; Magnefine Power Steering Filter; Edge Insight
07 Harley Ultra Classic Electra Glide
Rockster
rocky1074 is offline
post #7 of 8 Old 04-22-2012, 10:09 AM
cliffordbigred's Avatar
Would a BOV stop the "FART"? I have heard it not good on a
turbo.
cliffordbigred is offline
post #8 of 8 Old 04-22-2012, 11:41 AM
Powerstroke Techie
Quoted: 330 Post(s)
generally, diesels shouldn't need a BOV, since they don't have a throttle plate
kaya is online now
