I also have a wierd sound coming from inside
I have a wierd sound coming from the dash of my truck.........when i push the brake pedal down it stops! i have a manual shift if that helps. sounds like internet dial up or something
hell aint no tellin..... im gettin scared of this 6.0. it has 197,000 on it i guess if anything gonna go bad it would have already.
that sounds like the problem Im having. does it stop when you turn on the directional or step on the brake? I tore apart the lower dash looking for the source of the sound.the flasher is behind there thats were the noise was coming from . after I took it out and looked up the part number online I found info on another site were someone replaced the flasher and the noise didnt stop. turns out it was a problem with turn signal/ headlight dimmer switch . I wish I had a way to confirm that is always what causes this problem I would like to change it myself but dont want to just be throwing parts at it if its something else
