running rough
hi guys having a problem with my 05 F350 6.0 liter, have had problems since i owned it, dealer has replaced many parts, truck is idling rough, and when driving truck starts to buck when shifts into 3rd gear and rpm are between 1200-2000 over 2000 rpms runs fine any help would be appreciated thanks
Mine did the same thing turns out as injector stiction on #5. Replaced and it went away.
how do you tell which injector do i need to put it on computer
I work for ford so it's easy for me. You need to have your codes pulled and find put what's going on. I ran a powerbalance test and found the injector dropping out. Mine at first did not set a code had to run a power balance to find it. Hope this helps
thanks very much
Hey country mine would only do this in overdrive under 2000 rpm. Drove me crazy. Just find a dealer you can trust in your area so you don't get scammed.
been to 2 different dealers 3 oil pumps, injectors, turbo, fuel pump, sensors the list is endless the dealers dont have a clue and they keep it for a month every time waranty is up 147,000 miles
