ICP Sensor - Ford Powerstroke Diesel Forum
Old 03-09-2010, 10:56 AM
ICP Sensor
I Have a 2004 f250 6.0 that is in the shop. they said i need a ICP sensor and connector. Does anyone know where the icp sensor is located and how much one cost? The ford place is charging me 500 bucks and i just want to see how bad they popped it to me
Old 03-09-2010, 11:21 AM
It will depend on the time your 2004 was built, the sensor will either be on the passenger valve cover or behind the turbo on the 2003-2004 models. It's a snap to change if you have a 2004+ model, but the 2003-2004 are more difficult, you have to change it from under the truck, removing a shield.....
Mine went out on my '03, bought one from eBay for $50 and took an hour to put in. I didn't change the connector, just the switch.
Old 03-09-2010, 12:34 PM
Feedback Score: -1 reviews
sounds about right if you have an early 04 with the sensor on the pump. thte sensor and connector alone are 150 or so plus a couple hours labor and diag if you had them diag it.
Old 03-10-2010, 08:22 PM
i bought the sensor on ebay brand new for $65.00, about 10 min to install....
but my truck is an 05... much easier to work on
