Where is the MAP sensor - Ford Powerstroke Diesel Forum
Old 03-08-2010, 03:18 PM
Can anyone tell me where the MAP sensor is Located on a 2004 f250
Old 03-08-2010, 03:23 PM
Send a message via ICQ to VeeDubTDI Send a message via AIM to VeeDubTDI Send a message via MSN to VeeDubTDI Send a message via Yahoo to VeeDubTDI
The MAP sensor is a little black box mounted on the firewall above the passenger's side valve cover (near the oil fill). It has a small hose connected to it that goes to a port on the intake manifold.
Old 03-08-2010, 03:24 PM
Use this pic for reference, although this is a 7.3... sensor is in approximately the same location.
Old 03-08-2010, 03:25 PM
It's mounted to the heater box. follow the MAP hose coming from the right hand side of the intake manifold behind CAC pipe.
Old 04-25-2010, 10:27 PM
Yes, that's the same location on my 07. I'm trying to find a wiring diagram, or the color code for the signal wire to the ECM. JSM84
