can head gaskets randomly go bad? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-07-2010, 05:44 PM Thread Starter
jsr86's Avatar
my truck has a little bit of white smoke coming out every once and a while, when its idleing and when you first accelerate and i was just curious to know if head gaskets can just randomly go bad? the truck has never overheated or even came close either. ive had it for about a year. thanks
S&B Intake
SCT X4
EGR/DPF delete
jsr86 is offline
post #2 of 12 Old 03-07-2010, 05:57 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
I don't think that they should but guess can happen, usally on our 6.0 they blow from 2 much boost < high tunes >. or the oil cooler gets stoped up with coolant flow
< Flush coolant every 30,000 to help prevent that > and the coolant can't get to the egr in proper amounts and it gets hot and cracks and then coolant gets into our heads and hydrolock the motor, coolant in the oil ect.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #3 of 12 Old 03-07-2010, 06:03 PM Thread Starter
jsr86's Avatar
ok. ya i changed the coolant about 6 months ago with the motocraft gold coolant so that should be good. as far as boost, it is never really high. i have the sct and run the performance tune every day and it never goes over 20 lbs of boost, ever. the egr cooler has a plug welded into it so theres no exhaust going threw it but the coolant still goes threw it.
S&B Intake
SCT X4
EGR/DPF delete
jsr86 is offline
post #4 of 12 Old 03-07-2010, 06:12 PM
Goose350's Avatar
White smoke is either a bad injector(s) or a failed egr cooler.
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #5 of 12 Old 03-07-2010, 06:21 PM Thread Starter
jsr86's Avatar
hmm... ill take a bad egr cooler over head gasket any day. would it still be the injectors if the truck runs perfectly fine? doesn't hesitate, no loss of power... nothin
S&B Intake
SCT X4
EGR/DPF delete
jsr86 is offline
post #6 of 12 Old 03-07-2010, 06:29 PM
id think w/ an injector you'd have drivability issues of some sort.
when my egr went bad, it smoked a crap load on cold starts. other than that you couldn't tell.
when my headgaskets blew, basically just puking out the degas bottle was the only sign.
75' forty is offline
post #7 of 12 Old 03-07-2010, 06:34 PM Thread Starter
jsr86's Avatar
ok. nothin coming out of the degas bottle. it mostly does it when you first start it and if you just give it gas or take off. it doesnt do it all the time.
S&B Intake
SCT X4
EGR/DPF delete
jsr86 is offline
post #8 of 12 Old 03-07-2010, 07:18 PM
Goose350's Avatar
Park on a incline with the bed of the truck higher than the engine. Then pull your egr valve. If it is wet the it has failed.
The Mullet Mod
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #9 of 12 Old 03-07-2010, 07:24 PM Thread Starter
jsr86's Avatar
thats a good idea. im gonna do that in the morning, thanks. praying it is my cooler
S&B Intake
SCT X4
EGR/DPF delete
jsr86 is offline
post #10 of 12 Old 03-07-2010, 07:26 PM
Powerstroke Techie
forddieseldoctor's Avatar
head gaskets will not blow smoke. egr cooler will.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
