question about turbo install - Ford Powerstroke Diesel Forum
Old 03-06-2010, 04:41 PM
i pulled the turbo today to clean it. i have the turbo install kit from ford. i know the two bigger o rings, yellow, are for the tube (i believe this tube carries waste oil back into the motor) i think the smaller o ring is for the oil line where it comes out of the motor and heads to the turbo. how come there is only a gasket for the oil line at the turbo and not where it comes out of the motor? do you have to replace this o ring (it's blue). i was wondering if i am missing a gasket in the kit or is no gasket used there? there is also three spacers, i assume these are for the three bolts to attach the turbo. i have a 04, and there were no spacers when i took it off so i assume i don't need them.......
sorry for such a long post but i don't want to botch it..
thanks!
Old 03-07-2010, 05:37 PM
This is what I received in my kit. I think your missing the oil supply o-ring.
Turbocharger mounting kit
M® 2” finishing kit # 030050
1–1836770C2 oil supply gasket
1–1818402C2 oil drain o-ring
3-1844517C1 M8 X 30 bolt
3-1840739C1 spacer (2002-2003 only)
1-1844579C1 oil supply line o-ring
Permatex® Anti-Seize
Old 03-07-2010, 06:04 PM
Turning diesel into noise
Yes its your turbo drain tube and it allows the oil to re-enter your engine after it lubricates your turbo.
The "O" ring goes on the oil cooler side...
Hmm here is a for this one maybe one of the techs will elaborate but I think the spacers are for the '03-early '04 style pedestal...
Good luck and I you haven't already put some high temp anti-seize on those turbo bolts
Old 03-07-2010, 06:56 PM
Thanks for the responses, kind of a hard job and i wanted to be sure. the bolts came right out, the worst part was getting the turbo back in.
see ya
Old 03-07-2010, 07:08 PM
see ya
I know what you saying...been there, done that!!!! Good Luck
Old 03-07-2010, 07:18 PM
turbo had some pitting, didn't look too bad, all the vanes and the cam moved freely, so maybe it will be cool for 50,000. it has 145,000 on it now and thats the first time i pulled it. was a beotch separating the housing from the turbo,,but it's done and it's running good. maybe it will last a week...
Old 03-08-2010, 07:01 AM
I guess you did everything right.. Glad to hear it is running good..Every now and than drive it like you stole it..To Keep it cleaned out...
